Finishing Basement Question. - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-17-2012, 02:17 AM   #1
Finishing basement question.
Hey guys I'm new to the forums here. My question is when I do the 2.x4 wood framing, can I just leave a 2" gap between the wall for air space Nd not worry about a vapor barrier. The house was built 2 yrs ago. Also, can I just leave on the white wrap insulation they put on?
Thanks,
Mike
Stellsbells is offline   Reply With Quote
Old 01-17-2012, 08:42 AM   #2
DIY staff
Rewards Points: 7,174
Yes --leave a gap---Yes--leave the white wrap---
DrHicks (01-17-2012)
Old 01-17-2012, 08:59 AM   #3
Ok thanks.
Old 01-17-2012, 09:08 AM   #4
DIY staff
That white wrap is common in really cold areas--where are you?
Old 01-18-2012, 02:08 AM   #5
I live about thirty mins from buffalo,NY. And would you believe I went down in the basement today and spotted a hairline crack, barely a 1/16" and with the rain we had I noticed a little wetness on the wall. Minute though, ya think I can get away with using like dry lok on it? I'll have to pull the white wrap down on that spot of the wall to paint it, or do ya think I'm better off painting the whole basement walls with drylok now?
Thanks,
Mike
Old 01-18-2012, 10:09 AM   #6
DIY staff
Epoxy injection in the crack----Drylock is seldom needed as the exterior of the foundation is the place for the water proofing---
Any constant water seepage will break the bond on the Drylock and start seeping in short order---
Old 01-18-2012, 03:06 PM   #7
Yeah, that crack is like literally hairlike. Thin barely a 32nd of an inch. Just measures it. Not sure if I can get epoxy in there. Or does is just apply like paste? I'll have a look on YouTube and see if there are any vids on it
Old 01-18-2012, 03:10 PM   #8
DIY staff
Holes are drilled along the crack line---plastic nozzles are inserted then the epoxy is pumped in under great pressure,
Old 01-18-2012, 03:51 PM   #9
I just watched a video on, doesn't seem that bad.ok thanks for your help. Much appreciated
Old 01-18-2012, 07:33 PM   #10
Registered User
Rewards Points: 4,912
No air gap, no white poly, no dryloc.
http://joneakes.com/jons-fixit-database/743
http://www.buildingscience.com/docum...lation-systems
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
mae-ling (01-18-2012)
Old 01-19-2012, 04:48 PM   #11
Originally Posted by GBR in WA
Thank you for the links they worked out really great thank you very much
Basement Wall Finishing Question eaglefixr Remodeling 2 11-06-2011 10:09 PM
Finishing my Basement butchbs1985 Remodeling 15 06-06-2011 11:07 PM
Finishing Basement Wall - Stairs Along Concrete Rob1976 General DIY Discussions 5 02-02-2011 09:39 AM
Old Home - Basement addition insulation vapor barrier question 1870 Building & Construction 0 10-14-2010 08:36 AM
Noob question for basement finish electrical dtmbizzle Electrical 16 07-11-2007 08:08 AM
