Finishing Basement - Low Ceilings - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-05-2009, 07:16 PM   #1
Rewards Points: 14
Finishing basement - low ceilings
I'm going to be finishing my basement this year and I just took some measurements and it turns out my ceiling is a little lower than I originally expected. From cement floor to floor joist, the height is 7' 3". There is a beam running through the center of the basement with some duct work that comes down to about the height of the beam. The height from cement floor to the bottom of the beam is 6' 6". The code in my part of the country calls for a minimum ceiling height of 7' and allows the minimum height to drop to 6'8" for support beams and ducts. I remember reading somewhere that I could apply for an exemption when applying for my permit to allow the ceiling height to be a little lower than code if it is not possible to get to the minimum height. Is this true? Has anyone else finished their basement with low ceilings? What challenges did you face?
alyuka is offline   Reply With Quote
Old 01-05-2009, 09:13 PM   #2
General Contractor
Yes, you can apply for a variance(exemption) from the building department. Every building department handles this differently. It's best to call and ask what you need to apply for the variance.
jensenconstruction is offline   Reply With Quote
Finishing basement, had a few questions about ductwork... Wyjeep Plumbing 12 04-27-2010 10:27 PM
Finishing old basement force4ormore Building & Construction 1 12-29-2008 03:48 PM
finishing a basement jimmyfloyd Building & Construction 2 10-21-2008 01:30 PM
How to 'start' finishing the basement... mcvane Building & Construction 18 06-04-2007 09:28 AM
Finishing basement - electrical code ??? normwannabe Electrical 1 01-23-2006 08:48 PM
