Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 12-25-2012, 01:50 PM   #1
Finishing basement,insulation/vapor barrier questions
Ok I've read thru a bunch of post and can't really find the answers I'm looking for. I'm finishing my basement in northeastern pa. Cinder block wall and only the front of the house in below grade. Both sides and the back are completely above grade. I do not have a water or moisture problem. I started with dry locking all the walls anyway. I don't want to use foam insulation against the block. What's the best way to construct the wall and use fiberglass insulation. What kind of vapor barrier is needed to control condensation from the block wall between the finished interior wall? Would poly against the block wall then build a wall and drywall be the best Method? Thx for your advice.
samiam1017 is offline   Reply With Quote
Old 12-25-2012, 08:17 PM   #2
Moderator
No poly: http://www.buildingscience.com/docum...ts?full_view=1
http://www.carb-swa.com/articles/in%...Insulation.pdf
Gary
Clothes taking longer to dry?
Planning on finishing my basement gradually fenders Building & Construction 7 12-24-2011 01:31 PM
Newbie questions on refinishing walkup attic with knee walls FileOpen Insulation 2 11-20-2011 12:31 AM
A couple of noob concrete finishing questions SMRcalidiv Building & Construction 11 07-31-2011 08:27 PM
DIY electrical work questions for finishing a basement. mac41099 Electrical 7 11-16-2007 08:59 PM
finishing my basement Questions handyman1355 Building & Construction 4 10-18-2007 10:03 PM
