Finishing A Basement - Advice Needed - Remodeling - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-10-2012, 07:51 PM   #16
Registered User
Rewards Points: 5,212
You're welcome! Here are some more thoughts of mine on the edge sealing; Basement insulation and DRIcore The FL instructions are there if you move around a bit. The stairs will probably be slightly off, with the first (bottom) riser being shorter by the floor material's thickness. If easy enough, remove/replace the rough treads after cutting new stringers. Your local AHJ will inform you if the rest of basement requires to code/finishing if the square footage is over a certain percentage of total basement space, changes locally.
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
joe99 (09-10-2012)
Old 09-11-2012, 07:06 PM   #17
Rewards Points: 82
Gary
Back with more questions.
I have read through the the thread. I have also read through the documents you provided links to in this thread.
I understand the Delta FL concept. It makes sense. However, Dri-core is also a popular product. As you noted in the other thread, I also didn't like the idea of the "wood" part of Dri-core in the event of a flood. (As noted in one of the links you provided, the basement is the "final" place for all water to end up. Any flood will end up depositing water into the basement). That's what attracted me to Tyroc, which is basically dry-core with a topping that eliminated the potential water problem of dri-core.
So... if a dri-core type approach is so flawed, why hasn't it been "replaced" by a FL approach? Again, I see the benefits of an FL approach. I'm just trying to understand how a dri-core approach is still apparently popular/successful.
For the 750 sq ft I am looking at, dri-core, tyro and FL (with OSB) are all roughly the same cost. I would like to do what is "best" for the long term. If I go FL without OSB (which is preferable since I don't want am trying to avoid a wood product as a sub-floor), it is a lower cost and easier to install alternative.
That said, is FL really suitable as a base for a floating laminate floor? Maybe FL is more rigid than I imagine, but it seems odd to put flooring on top of a dimpled plastic sheet that comes in rolls. Will this provide a "solid" floor, or is something like OSB on the FL a better way to go?
Out of curiosity - what does AHJ stand for? I am guessing it is the code enforcement officer/inspector (which is all we have in this area). Just wondering what the acronym is.
joe99 is offline   Reply With Quote
Old 09-12-2012, 10:15 PM   #18
Registered User
AHJ = Authority Having Jurisdiction.
You will need to do a little more research for particular answers. eg.; http://www.avsforum.com/avs-vb/archi.../t-676110.html
Both pages...
Gary
How to - prevent basement mold crazymountain How To Guides 36 07-23-2014 07:02 PM
Advice on priority of repairs: gutters and basement nshroyer Building & Construction 10 07-06-2011 09:40 PM
Finishing Basement Wall - Stairs Along Concrete Rob1976 General DIY Discussions 5 02-02-2011 09:39 AM
pre-stubbed basement bath vent needed? ameleus Plumbing 7 09-21-2008 11:26 AM
Basement Floor Finishing, Advise Needed dbbyleo Flooring 5 04-25-2008 12:32 PM
