Finished Loft - Remodeling - DIY Chatroom Home Improvement Forum
Old 12-01-2007, 07:04 PM   #1
Finished Loft
I am finishing my loft and I am curious what the best way to insulate the roof is. I am going to frame 4' walls on each side to close off the dead space then i will have collar ties to flatten off the cieling at the top. there is soffit vent but no ridge vent. I am pretty sure the roof is an 8/12 pitch. Thanks for any suggestions or help that can be given.
Jon M
jmontgom is offline   Reply With Quote
Old 12-02-2007, 12:40 PM   #2
Woodworker and Contractor
Kingfisher's Avatar
Rewards Points: 150
even without a ridge vent you can't pack the insulation up against the roof. They make foam batten to create the chase under the roof and hold the insulaition away. Any lumber store will have them and they staple up quickly the nfill the rest of the space with insulation.
Kingfisher is offline   Reply With Quote
Old 12-02-2007, 01:25 PM   #3
Rewards Points: 5,336
You'll need to install vents on the top side for proper ventilation. How many will depend on the size of the space. You should plan to put up as much insulation (or as close as you can get to) as the region you live in calls for. The insulation should be installed in the floor behind the 4' walls you're building, up the walls and around the living space. A visual will be seen on the insulation manufacturers web site.
Ron
Old 12-03-2007, 06:59 PM   #4
thanks for the reply's guys i will let you know how it turns out
How would i finish this loft???? (pics) oregonrebel Building & Construction 3 03-31-2007 08:01 AM
Ideas for a loft? kcrossley2 Building & Construction 2 12-18-2006 06:32 PM
Bathroom Outlets - How far above finished cabinet height? MikeinBurien Electrical 4 12-10-2005 11:11 AM
Question About Bolting Wood Together for a Loft ArcticRSXS Building & Construction 15 09-16-2005 04:42 PM
