-   -   Finished Basement Quandry (http://www.diychatroom.com/f15/finished-basement-quandry-20455/)
SonOfPirate 04-29-2008 01:33 PM
We are in the process of finishing our basement but have run into a bit of a dilemma that I'm hoping someone else has encountered and can recommend a solution.
Our basement is essentially divided lengthwise into two areas. One half contains all of the utilities, furnace, water conditioner, sump basin and laundry area. The other is wide open. Our intent is to finish the open portion and turn it into a useful space for entertaining.
Dividing these two areas is the support I-beam running the length of the basement. A closet already exists at one end running parallel to the I-beam and the stairwell ends at the I-beam at the other end. This seems perfect except that the I-beam is only 75 inches above the poured concrete floor and being 6 feet tall, I am already acutely aware of this height. In addition, running along the "backside" of the I-beam is the main heat/air duct.
Putting up a wall is not an issue as I can certainly work around the I-beam - in fact, my father suggested using 2x6 boards notched around the I-beam to frame in the dividing wall. My problem is that we need some sort of doorway between the two halves of the basement. To put a door into this wall would require me to cut it down to a 75" height, leaving virtually no headroom for a 6' person to walk through (and forcing anyone taller to duck). I am simply hesitant to do this.
Because of the duct, I'd have to recess the doorway at least 2 feet beyond the wall in order to make it standard height. And, in my mind, this would look pretty ridiculous because the ceiling at the I-beam and across the bottom of the duct would suddenly rise vertically at the door opening. (Make sense?)
Has anyone run into this? I realize that I can change my design but I'm trying to work with the existing construction (closet and staircase) and maximize the space we have in the "main" room while not reducing the other half beyond utility.
Any suggestions/thoughts?
perpetual98 04-29-2008 02:34 PM
Well, the simple fact is that you're looking at a 75" height limit and there isn't much you can reasonably do about that. You can cut doors down to that height, or you could perhaps lop your feet off about mid-shin. :)
Do you "require" a door there? How about just an opening? That would save you a little bit of room at least. My in-laws basement had a real low section of their ceiling. Only took me about 3 or 4 times of walking into it before I learned it was there and avoided it. :)
SonOfPirate 04-29-2008 02:40 PM
Yea, some sort of door will be required. We don't plan to finish the other side of the basement and we won't it open to public view when entertaining.
47_47 04-29-2008 02:42 PM
This door leads to the mechanical / storage area. I'd put it under the beam. Because you will have to cut it down, I'd lean toward a 36" door.
Added, You will also lose the height of your finished floor and ~ 3/4" for the top jamb.
skymaster 04-29-2008 04:53 PM
Only other thought I have is to frame your wall in front of that girder, open door into the finished room. If you keep tight to the girder than you only lose 41/2" of width from the room, just remember to keep enuf space on the back side for the jamb to remain flush to the front
perpetual98 04-29-2008 05:23 PM
1 Attachment(s)
Kick the door away from the beam. You're still going to have the beam to deal with, but not the door.
