Finished Basement Flooded Few Q's - Remodeling - DIY Chatroom Home Improvement Forum
Old 12-28-2008, 10:44 AM   #1
Both regular and back-up sump failed yesterday. Got enough seepage that the carpet/padding was soaked.
I removed all carpeting and padding and have a industrial blower, dehumidifier and heaters running. My main concern at this point is the drywall and insulation. There is no signs of water on baseboard or drywall other than feeling slightly damp. There's a vapor barrier between the basement wall and insulation.
I removed 1 baseboard and the wall is slightly damp from floor to about 3 inches up. I was going to drill 1" holes every 12 inches and check the insulation. If it's slightly damp, hit it hard with more blowers and heat to dry it out. If it's soaked, cut the drywall about a foot up all around the room and remove the insulation, let it dry, replace insulation and drywall.
I this prudent, do I need to take additional steps? I don't want to create work, but I don't want a mold issue this summer. Im in chicago area, so at the moment it's cold. Most the basement looks pretty dried out aready. Do I bite the bullet and cut the drywall, or drill and make sure it's not soaked and try to dry it out?
Thanks for the help.
Weekendwarrior42 is offline   Reply With Quote
Old 12-28-2008, 10:56 AM   #2
call your insurance man ,after taking photos first.
butlersprints is offline   Reply With Quote
Old 12-29-2008, 09:05 AM   #3
Mold!! Let's kill it!
Rewards Points: 2,012
Unless you can get the drywall dried out within 72 hours, it should be replaced. It should be cut 1 foot above the line where it got wet. Agreed, the first step should be to call your insurance company.
Old 12-29-2008, 06:40 PM   #4
Drywall contractor
Rewards Points: 1,070
If the amount of water was minimal and not standing for a long time, you may be ok. Drywall will"wick" moisture as long as it's standing in it. Discoloring may take a couple of days and mold even longer to show up. If you're going replace and do the drywall work yourself, go ahead and remove the whole bottom sheet of drywall and replace it (assuming it's laid down, not stood up). That way you have your tapered edges to finish instead of a "butt" joint (and at a more comfortable working height). A few more dollars for material, but a lot easier labor-wise. Especially if you're not an experienced finisher.....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Vapor barrier requirement for finished basement JTK Building & Construction 13 02-05-2011 05:30 PM
adding Insulation to finished basement Mr Chips Remodeling 2 03-23-2008 11:16 AM
New poster, looking for advise on heating cooling in basement that is being finished blthomas HVAC 11 12-07-2007 11:07 AM
Flooded basement and Mold Remediation? Lightyear General DIY Discussions 34 04-25-2007 08:09 AM
