Finished Attic With Metal Roof - Remodeling - DIY Chatroom Home Improvement Forum
Old 05-12-2010, 04:08 AM   #1
Finished Attic with Metal Roof
I have a finished attic with a metal roof. The roof pitch is about 14-12 and there is no venting at all. I have box gutters with a soffit, but no vents. The finished attic has drywall, wool insulation in a plastic bag, then planks every other row, then the metal roof. There isn't really a knee wall. Just about 10" between the floor and slope of the roof.
Obviously my drywall keeps cracking because there is moisture. I have cut out sections to verify that the roof doesn't leak. How do I vent an attic like this? Can ridge vents be installed on metal roofs? Right now there are zero vents on roof or soffits.
jonathan03 is offline   Reply With Quote
Old 05-12-2010, 07:55 PM   #2
kwikfishron's Avatar
Rewards Points: 798
You must have venting in every bay. Continues vent at the soffits and ridge vent on top.
You must have at least 1” clear between the insulation and the roof sheathing.
kwikfishron is online now   Reply With Quote
Old 05-13-2010, 03:22 AM   #3
Can I put a ridge vent on a metal roof after the fact?
Old 05-13-2010, 05:50 AM   #4
Rewards Points: 798
It can be done, but if any one of the three pieces of the puzzle aren’t in place your defeating the purpose.
condensation leak with metal roof on cathedral ceiling in Canada Serialrenovator Roofing/Siding 10 02-02-2010 12:18 AM
Metal roof vs asphalt shingle roof Bob_T Roofing/Siding 1 06-20-2009 05:51 PM
Split level walls and floor joists - how are they constructed? jrbutterfly Building & Construction 2 06-09-2009 12:11 PM
Powered Attic Fan question spup345 Roofing/Siding 9 06-30-2008 08:10 PM
Metal versus Traditional Shingle Roof 4powells Building & Construction 2 04-28-2005 09:40 AM
