Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 11-12-2008, 01:45 PM   #1
Post
Finish table edge after pouring epoxy
I recently bought a restaurant and refinished all of the tabletops with a collage of vinyl records and album covers. I then poured several layers of epoxy over about a weeks time to achieve a 1/2" thickness. Long story short, the epoxy has cured, the tape is off, and I am ready to finish the edges, which are sharp and uneven. Any suggestions for the best way to get a smooth, rounded edge?
thepiedpiper is offline   Reply With Quote
Old 11-12-2008, 01:58 PM   #2
RippySkippy's Avatar
Router, carbide round over bit (they come in various sizes) and safety glasses for you.
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 11-12-2008, 08:45 PM   #3
Man of many hats
wrangler's Avatar
Another option would be a belt sander. First, 'ease' the edges with a razor knife to reduce the amount of sanding needed, then work your way down from 60 to 400 grit sand paper. The belt will get clogged if you try to sand too much at one time, but you can get more use out of a belt by brushing it with a brass brush. If you are wanting a 'glass' or clear edge, you will have to eventually work down to a very fine grit(2000). Water will help with the final sandings.
Man of many hats
wrangler is offline   Reply With Quote
Old 11-17-2008, 09:12 PM   #4
update: i ended up using an electric sander with very fine sandpaper, and the edges turned out very smooth with only a little cloudiness in thicker spots. thanks for the advice, ya'll!! if you're ever in nashville, stop by the pied piper eatery and i will treat you to some egg sandwiches.
Tags
epoxy
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 10:07 PM
How do I finish the edge ot my Raised Patio rabih_00 Landscaping & Lawn Care 4 09-08-2008 03:10 PM
Best way to finish ruff barn-board for indoor table? BradG Painting 4 07-29-2008 12:26 AM
Best protective finish for old barn-board, used as table? BradG Painting 8 06-18-2008 12:30 PM
Shingle Installation with F5S Standard Drip Edge ShortEdged Roofing 32 02-15-2008 03:10 PM
