-   -   Finish table edge after pouring epoxy (http://www.diychatroom.com/f15/finish-table-edge-after-pouring-epoxy-31727/)
thepiedpiper 11-12-2008 12:45 PM
I recently bought a restaurant and refinished all of the tabletops with a collage of vinyl records and album covers. I then poured several layers of epoxy over about a weeks time to achieve a 1/2" thickness. Long story short, the epoxy has cured, the tape is off, and I am ready to finish the edges, which are sharp and uneven. Any suggestions for the best way to get a smooth, rounded edge?
RippySkippy 11-12-2008 12:58 PM
Router, carbide round over bit (they come in various sizes) and safety glasses for you.
wrangler 11-12-2008 07:45 PM
Another option would be a belt sander. First, 'ease' the edges with a razor knife to reduce the amount of sanding needed, then work your way down from 60 to 400 grit sand paper. The belt will get clogged if you try to sand too much at one time, but you can get more use out of a belt by brushing it with a brass brush. If you are wanting a 'glass' or clear edge, you will have to eventually work down to a very fine grit(2000). Water will help with the final sandings.
thepiedpiper 11-17-2008 08:12 PM
update: i ended up using an electric sander with very fine sandpaper, and the edges turned out very smooth with only a little cloudiness in thicker spots. thanks for the advice, ya'll!! if you're ever in nashville, stop by the pied piper eatery and i will treat you to some egg sandwiches.
