Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 11-03-2012, 10:09 PM   #1
Finish basement/drain pipe
Hello-
I would like to finish my basement. My house is about 5 years old and when the drain pipe was installed, it was installed about 4 feet from the floor. The drain pipe starts from the back of the house through 3 different walls to the front of the house. My question is, could/should drain pipes be covered behind drywall?
Thanks in advance!
jenze is offline   Reply With Quote
Old 11-03-2012, 10:14 PM   #2
WIthout a picture it's hard to picture what your taliking about.
Old 11-03-2012, 10:19 PM   #3
I guess it would help. Thanks!
Finish basement/drain pipe-image-2881952601.jpg   Finish basement/drain pipe-image-2079318794.jpg
Old 11-03-2012, 11:08 PM   #4
i would fram the wall out far enough that you could get to the pipes in case of a problem. can you squeez through 18 inches?
Old 11-04-2012, 06:32 AM   #5
Super Moderator
As long as any clean outs are still accessible----you can frame tight to the pipes---) leave a little wiggle room---1/2" is plenty----
Cutting and gluing PVC pipe to washer steve3847 Plumbing 8 10-03-2012 09:00 AM
Condensation in Gas Furnace Vent Pipe chanco HVAC 2 01-08-2011 05:01 PM
Buried gas pipe in conduit WillK Plumbing 4 01-07-2011 01:50 PM
Septic/sewer pipe replacement Mendocino Plumbing 4 11-21-2008 06:40 PM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 12:09 PM
