Finding Studs In A Lath And Plaster Wall - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-28-2008, 05:03 PM   #1
Finding studs in a lath and plaster wall
Is there any stud finder or something similar, that would locate studs in a lath and plaster wall?
Thanks.
Oilerz is offline   Reply With Quote
Old 02-28-2008, 05:16 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
First option: http://www.grainger.com/Grainger/items/6R328
(You may have to click on this a few times, for the image/link to show up)
Second option:
This is where you need to go backwards in technology.
New stud finders will not work on plaster and lathing walls, as you already know. So, what you need is an old fashioned magnetic stud finder.
The kind that has a magnet that sits on a pivot and stands up when it finds a nail.
The reason being that the lathing is attached to the studs with nails.
Good Luck (with option 2)
- Build Well -
Old 02-28-2008, 06:56 PM   #3
Oldguy
Rehabber's Avatar
I like option #1
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 02-28-2008, 10:24 PM   #4
Thumbs up
I think I'm going to have this Problem
Yeah plaster and Lathe. That sounds like me for sure This was going to be a "Future" Question for sure.....
Tdoggy187 is offline   Reply With Quote
Old 02-29-2008, 06:43 PM   #5
Originally Posted by Rehabber View Post
I like option #1
Ya, that AWBC always has the right answers.
Handyman50 is offline   Reply With Quote
Old 03-01-2008, 05:11 AM   #6
Off course that would be the 15#r right?
mark942 is offline   Reply With Quote
Old 03-01-2008, 08:51 AM   #7
Rewards Points: 5,336
You can use the outlets and switches as guidelines. They are face nailed to the stud. Once you find one or two the others will generally be 16" on center. You can also use your knuckle and knock on the wall. The pitch between a stud is lower then when you get to the stud.
A decent tool is the "wizard". It detects metal in boards before you put it through a planer or jointer. It's sort of like those wands they have when you go through security.
Ron
Old 03-02-2008, 03:10 PM   #8
Knucklez's Avatar
Rewards Points: 930
i use a 4" long super strong rare earth magnet to find the nails in the studs. purchased from ebay cheap.
also the switches and recepticals as guidelines will give you a clue as previously posted.
Knucklez
Knucklez is offline   Reply With Quote
Old 03-03-2008, 12:52 AM   #9
Long-Time DIYer
Mike Swearingen's Avatar
Some old houses with lathe and plaster walls have studs on 24" centers, so drill very small pilot holes when you find the right sound to be for sure...16" or 24" centers.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Fishing through plaster and lath walls?? slatergrl Electrical 7 02-05-2008 09:29 AM
Asbestos in plaster? Erebus Remodeling 1 02-15-2007 09:13 AM
replacing lathe and plaster eager2lern Building & Construction 2 12-04-2006 01:52 PM
Plaster removal decision Sarai Remodeling 2 09-08-2006 04:15 PM
Remodeling Old Room - Removing Plaster, lath- worried about Stud Straightness JoeSmith Remodeling 3 04-22-2006 01:41 AM
