Filling An Odd Opening - Remodeling - DIY Chatroom Home Improvement Forum
Old 06-01-2013, 11:41 PM   #1
filling an odd opening
I am adding tile to my bar area. At the same time there is an odd opening by the sink that I'm trying to coverup. There is a small mini refrigerator in this area, but I need to cover the opening.
What can I use? It must be easy to open, but yet sturdy just in case if there is a water leak, etc.....
valpd is offline   Reply With Quote
Old 06-01-2013, 11:42 PM   #2
Here's a pic
Old 06-02-2013, 07:05 AM   #3
Bill Kearney
Rewards Points: 1,174
Make a panel for the opening and use screws, from the inside, to hold it in place. Either cover it with spare paneling that matches what you've got on the walls or chose something complimentary to the rest of the room.
The panel could just be a simple bit of plywood with a 2x2 or 2x4 frame around the back of it.
wkearney99 is offline   Reply With Quote
Old 06-04-2013, 02:30 PM   #4
Rewards Points: 6,089
Where is the mini fridge?
Two Knots is offline   Reply With Quote
Old 06-04-2013, 03:12 PM   #5
In this area
Old 06-04-2013, 03:40 PM   #6
[QUOTE=valpd;1195135]In this area[/QUOTE
I figured that...
why aren't you putting doors in the area you want to close off?
the extra storage area would come in handy, no?
Old 06-04-2013, 03:50 PM   #7
That's what I was thinking. I have a huge storage area though.
Old 06-04-2013, 04:06 PM   #8
That's really nice, I would make a door for it, and keep my garbage pail
in there.
Put the hinges on the wall side, so it's easy to open from standing
in front of the sink.
When is the party?
Old 06-04-2013, 04:31 PM   #9
in there.
When is the party?
The garbage pail is under the sink already. The opening is to the left of that.
Old 06-05-2013, 06:26 PM   #10
Rewards Points: 258
Match what you have by the china cabinet
redman88 is offline   Reply With Quote
The Following User Says Thank You to redman88 For This Useful Post:
oh'mike (06-05-2013)
Old 06-05-2013, 10:50 PM   #11
We didn't build this bar. The previous owner did. I'll have to find out where I can get the same type of door.
Old 06-05-2013, 11:02 PM   #12
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 5,622
Just an idea....looks like unstained flat panel hickory to me... try going to Floor Decor... bet they have a pretty close matching flooring.... and build the panel/door?
For small trim pieces in remodels, I find alot of matching pieces in flooring selections... alot of choices, and you do not have to screw with multiple attempts at matching stain and varnish.
MTN REMODEL LLC is offline   Reply With Quote
The Following User Says Thank You to MTN REMODEL LLC For This Useful Post:
valpd (06-05-2013)
Old 06-06-2013, 01:18 AM   #13
Too much wood IMHO - may look cool if you get a canvas picture/printout of something (sports team, band, something that goes with the bar theme - whatever) and used that as a removable panel. Staple it onto some plywood in the back to keep the look clean and make it oversized to cover the entire side if you want. Plenty of places to have whatever you want printed onto a canvas material online. Can even add some padding to give it a plush look if you'd like
Hawktomegoose is offline   Reply With Quote
Old 06-06-2013, 01:18 PM   #14
Rewards Points: 150
Looks like pine cabinet ends and paneling, hickory glue up doors, maple face frames and top. Are the other cabinet ends T&G pine?
zakany is offline   Reply With Quote
Changing Window Size TinaV Remodeling 3 11-06-2012 01:30 PM
creating an opening bearing or not? Wiscbldr Building & Construction 2 11-01-2010 03:32 PM
Putting a wall over a large opening, need ideas aqzman Building & Construction 5 10-28-2009 04:46 PM
Installing closet doors into un-true opening - Need ideas McCool Carpentry 8 08-12-2009 02:37 PM
Finishing opening for closet Frank_N_Stein Carpentry 11 12-24-2008 09:52 PM
