Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 07-07-2004, 08:43 PM   #1
Grumpy's Avatar
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
A facelift for your home
If you’re considering moving, not because you’ve outgrown your home but because your house no longer has that same luster it once had; you may want to consider a facelift for your home. A facelift is not as involved or expensive as it sounds. A facelift on your building may just bring back that excitement you had when you first purchased it, and IS cheaper than purchasing a new home.
The facelift process is simple; it is basically an exterior renovation. Not much is being changed but the end result is wondrous! First determine what it is you don’t like about your home. This can be depressing but is important because if you don’t know what’s wrong, you don’t know what to fix. Is your roof drab and dull? Is your paint peeling and chipping? Are your windows outdated and leaky?
The solution is easy, takes a few weeks, and will once again make your house the best looking on the block. Because your roof and walls have the most exposure these should be your main considerations in livening up your home. Consider replacing your roof and installing maintenance free vinyl siding on your walls. These two steps alone will revolutionize your home’s look. Consider changing the color scheme to something more modern.
If your windows are outdated you may want to have replacement windows installed. If it’s not in the budget make sure the frames are capped when having your siding installed. Capping your windows is cheap and can add some curb appeal to your house. Completely changing out your windows will allow you to install the newest style and best protecting glass.
The exterior of you’re home if the first impressions of you’re home. There is no second chance to make a first impression, so make the right impression.
Written in January 2003 by Thomas Kral, the founder of Reliable American, Inc. Reliable American is a firm specializing in roofing and remodeling. www.reliableamerican.us
-Grumpy
Chicago Roofing Chicago Gutters
Sometimes the savings that comes from doing it yourself can be blown away with one mistake.
The information found in this post is not to be considered legal advice. All information should be considered relative, not specific. Never attempt any repairs you are not comfortable with. Always maintain saftey! The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
More On This Topic
When a fire safety ladder is is just a ladder with rungs and chains so it can be easily stored and when you deploy it, it just rolls out and rolls either down the roof or just down the side of your house and it hooks right on the side of your window sill... Read More »
If you're living in a mobile home and facing your first winter, you may not be aware how difficult it can be to keep a mobile home warm. Taking the proper steps to winterize your mobile home cannot only help keep you warm, but keep your heating bills... Read More »
Straw homes have come a long way from the days of the "Three Little Pigs." Despite the fears of traditional homebuilders, homes made from bales of straw have proven to be structurally sound, well insulated and environmentally friendly. Another big... Read More »
It’s important for every home owner to familiarize themselves with the exterior of their house. A lot of times people don’t check on what’s going on outside their house. Especially on the side that they rarely see - until there’s... Read More »
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
