Exterior Wall Insulation - Remodeling - DIY Chatroom Home Improvement Forum
Old 11-06-2007, 10:32 AM   #1
Exterior wall insulation
I live in Milwaukee, Wisconsin. I want to insulate the exterior wall of a closet. I have all the drywall removed. The wall stud space is 16" on center, 2 X 4 construction. What kind of insulation do I use? Unfaced? Vapor barrier? "R" factor? The previous insulation was unfaced with plastic stapled to the studs, then drywalled.
Thanks...
Gus
ffgus is offline   Reply With Quote
Old 11-06-2007, 11:27 AM   #2
Hey Gus. Don't have an answer for you, but have the same question for my garage which is unfinished that I'd like to some day finish off and insulate. I live out by Oconomowoc.
Eric
perpetual98 is offline   Reply With Quote
Old 11-06-2007, 11:53 AM   #3
Hey, Eric,
Go to the Owens Corning website. I found a great little helper there for insulation guidelines. If you enter our zip code, it tells you what insulation to use for what part of the house.
Hope this helps...
Gus.
Old 11-06-2007, 01:32 PM   #4
Hang on. The OC website gives you nice tips for how much insulation they recommend for where you live, but you can only put as much insulation as you have space for.
In a 2x4 wall, you can only install R-13 fiberglass. Use faced, and staple the kraft paper to the studs, towards the inside of the house, then drywall over. Or use unfaced, and put up plastic. Either way.
If you put R-19 in a 2x4 wall you'll have performance that is worse than R-13 because insulation works poorly when compressed.
NateHanson is offline   Reply With Quote
Old 11-06-2007, 04:23 PM   #5
Rewards Points: 150
Me a diy'er
I am not trying to make an easy job hard AND I am just a diy'er.
IF your closet has suffiecient depth you 'could' add a 2X2 onto the 2X4 studs and make an R-19 cavity out of it. IF sufficient depth is NOT an issue and no other obstacles like windows etc. BUT rememeber IF your just doing the minimal area of a closet that way,,,Not a great percentage of overall wall area so cost vs benefit???? IF you are thinking of remodeling the whole inside structure,,,then you may or may not be worthwhile,,,OR find a 2X6 wall house to start with for energy conservation purposes,,it aint gonna get no cheaper(heat). BUT plan the whole house,not 1% of it and expect to see a difference!!
justdon is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
attic insulation question dderolph Building & Construction 10 11-03-2007 05:21 PM
dormer window insulation wlm-21 Building & Construction 2 02-13-2007 04:04 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 08:33 PM
Insulation material reusable? KUIPORNG General DIY Discussions 4 06-19-2006 02:38 PM
