Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 10-23-2010, 01:55 AM   #1
exterior shutter size
I need to replace the exterior shutters on my home. I cannot find shutters that are the same size as the ones that are on my house currently. Since I am going to have to go with a different size, I need to know what width shutter would look best on windows that are 28-30 inches wide (excluding trim). The shutters only come in two width sizes: 12 inch and 15 inch. I have a colonial house with 12 sets of shutters so I don't want to make a mistake on the shutter size. Any advice would be appreciated.
dillo1 is offline   Reply With Quote
Old 10-23-2010, 06:28 AM   #2
Check a local building supply house for shutters. They usually have custom sizes available. Standard widths are 14-15", standard heights are usually about 3" apart.
Old 10-26-2010, 12:49 PM   #3
If you were going with standard widths, I would guess 15" would make sense since it would look the most realistic on a 30" wide window. Anything less would be too narrow for functional shutters to actually close properly.
operagost is offline   Reply With Quote
Old 10-07-2011, 01:25 PM   #4
I'd suggest going with the 15" - as operagost mentioned, it's important that they look like they can cover the whole window when closed, even if they're decorative shutters.
KB36 is offline   Reply With Quote
Old 10-08-2011, 08:45 AM   #5
Get the size closest to your size now.
Ron
B. Franklin 1759
Old 04-26-2012, 05:54 AM   #6
I think 15 inch shutter size is perfect for your windows. There are many shutters services providers, you can take help from these service provider. They will gives you best suggestion.
exterior shutters
payalmittalmay is offline   Reply With Quote
Old 04-27-2012, 06:56 PM   #7
sdsester's Avatar
Decorative shutters are a pet peeve of mine. Shutters are supposed to cover windows. The width on each side, to look at all authentic should be half the width of the window. The faux ones often look stupid they are so narrow and out of scale.
sdsester is offline   Reply With Quote
The Following User Says Thank You to sdsester For This Useful Post:
goosebarry (04-28-2012)
Size of whole house fan needed Doug Crf General Discussion 20 02-26-2011 12:29 AM
What Size Crown Molding? Jim McClain Interior Decorating 1 10-04-2010 08:16 AM
Determining Boot/Register Size Earnie HVAC 15 12-31-2009 06:00 PM
Building a patio cover...span and size of lumber Q's jongordo8 Building & Construction 1 08-30-2009 01:08 AM
duct work size justmefixin HVAC 2 09-20-2008 07:59 PM
