Exterior Sheathing? - Remodeling - DIY Chatroom Home Improvement Forum
Old 07-17-2012, 07:10 PM   #1
Exterior Sheathing?
Hi,
I have a 55 year old single-story home. A few years ago I had my siding and windows replaced. After the initial tear-off, this is what I was left with. Vinyl siding was installed directly over top of this. When I look back to these pictures, I wonder if I should have replaced all of the "sheathing." What it has is Johns-Manville Weathertite, and then you can see there is some-sort of blue-painted wood about 1/2-way down the side of the house, which is installed over top of the Weathertite. The Weathertite is not wood, but sort-of like a foam/fibrous material. It damages very easily, as you can see the holes in it that came from removing the old aluminum siding.
No housewrap was installed, and obviously as shown, neither was any flashing. I did not have Angie's list at the time, and ended up with a nightmare of a contractor with a criminal record.
As of now, 3 years later, I do not have any apparent water leaks into the interior space.
Any recommendations or commentary are welcome. This is my rental property.
Thanks.
carluvr is offline   Reply With Quote
Old 07-17-2012, 07:17 PM   #2
Tom Struble's Avatar
Rewards Points: 2,002
what are you asking?
Tom Struble is offline   Reply With Quote
Old 07-17-2012, 07:39 PM   #3
I wonder if I should have re-sheathed the whole house?
Do the holes in the Weathertite behind the vinyl siding in the attic space area pose a problem?
What would you do if this was your house, now covered with vinyl siding?
Old 07-17-2012, 08:47 PM   #4
Rewards Points: 13,250
To late now, unless you plan on taking it all off. That looks like T-111 at the bottom, no need to have remove it unless there was some rot. I'm not a big fan of that poop that was used at the top, but they should have at least replaced the trashed pieces.
I would have gone over everything with house wrap before the siding.
Old 07-17-2012, 08:47 PM   #5
firehawkmph's Avatar
Rewards Points: 1,822
Car,
depends on how big the house is. If it were mine, I'm a plywood guy. I would take everything down and resheat the house with 1/2" cdx, housewrap, then the vinyl siding. If you are versed in this kind of work, its a job, but if you attack it one side at a time, it's doable. If you have to pay to get it done, it's a lot of money. I have worked on a lot of houses that were sheeted with that type of material. We used to call it celotex, probably a brand name and not the proper name. I hate the stuff.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 07-17-2012, 08:51 PM   #6
There was a time when it was legal to do all the walls with it and only have to put plywood on the outside corners.
Old 07-17-2012, 09:06 PM   #7
Originally Posted by firehawkmph View Post
Car,
Mike Hawkins
Mike,
Can that be done separately from a new roof? Does housewrap tie into the roof in any way?
Old 07-17-2012, 09:21 PM   #8
House wrap has nothing to do with the roofing.
But if you had of remove the black board to install plywood you would have had to remove the fashia boards under the rakes, which may well mess up the shingle moulding.
Old 07-17-2012, 09:57 PM   #9
i would leave the bottom,sheath the gable [same thickness] housewrap and side the whole thing
Old 07-18-2012, 10:29 PM   #10
That sounds like a good way to go Tom. Make sure the T1-11 is nailed tight and go to it.
Mike Hawkins
