Exterior Gypsum Sheathing - Remodeling - DIY Chatroom Home Improvement Forum
Old 06-19-2008, 09:48 AM   #1
Exterior Gypsum sheathing
My 1970's vintage brick ranch house was sheathed with a gypsum product. Due to a leaking tiled shower the bottom 18 inches of the backside of the shealthing had some mold. I cleaned the mold. Now the paper backing has peeled from the gypsum.
I realized replacing the sheathing would be the ideal. I am trying to avoid that at all costs.
Do I need to seal the gypsum before I insulate?
If I need to seal it how do I do that?
Badkarmaagain is offline   Reply With Quote
Old 06-19-2008, 01:39 PM   #2
Mold!! Let's kill it!
Rewards Points: 2,012
If the gypsum is basically intact, but has only lost the paper facer, I would seal it with Kilz. You should really test it for moisture content first, to make sure it has completely dried. If you can beg or borrow a moisture meter, test it and compare your reading to a known dry sample of the same material close by.
Roof sheathing overhang on fascia Clutchcargo Roofing/Siding 7 08-23-2007 01:02 AM
roof sheathing placement dmend Roofing/Siding 1 03-20-2006 09:03 PM
Roof Sheathing Acceptable Tolerances? claypj Roofing/Siding 2 08-15-2005 03:16 PM
