Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 01-13-2010, 02:35 PM   #1
Exterior door in Interior Jamb??
Wanting to hang an exterior grade door in an existing opening that currently has a typical hollow-core door leading into our cold room in basement.
Question is do I have to strip all the way back to the jamb or can I hang the exterior door in existing jamb space??
jrmac99 is offline   Reply With Quote
Old 01-13-2010, 02:52 PM   #2
Remodeling Contractor
The only difference between interior and exterior jams is the exterior has built in weather stripping and a weather tight threshold. Both can be removed. Or to the interior both can be added. But the hinge location and size is also different.
Old 01-18-2010, 12:37 PM   #3
Drywall contractor
If it's a typical pre-hung interior door with a "split" jamb, I wouldn't hang an exterior door on it. The exterior jamb is stronger and will support the heavier door better. Besides the difference in hinge size, some older interior pre-hung doors only came with two hinges and an exterior would require three. (The ones I tore out of my house had only two.) A pre-hung exterior door would be easy to install, and as Bob mentioned comes with all the appropriate weatherstripping and a threshold to seal it tightly.....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is online now   Reply With Quote
Old 01-18-2010, 01:28 PM   #4
Exterior doors are normally 1 3/4", while interior doors are 1 3/8" thick. The stops would have to be moved.
Work is for those who can not fish.
Mop in Hand is offline   Reply With Quote
