-   -   Exterior door in Interior Jamb?? (http://www.diychatroom.com/f15/exterior-door-interior-jamb-61768/)
jrmac99 01-13-2010 01:35 PM
Wanting to hang an exterior grade door in an existing opening that currently has a typical hollow-core door leading into our cold room in basement.
Question is do I have to strip all the way back to the jamb or can I hang the exterior door in existing jamb space??
Bob Mariani 01-13-2010 01:52 PM
The only difference between interior and exterior jams is the exterior has built in weather stripping and a weather tight threshold. Both can be removed. Or to the interior both can be added. But the hinge location and size is also different.
bjbatlanta 01-18-2010 11:37 AM
If it's a typical pre-hung interior door with a "split" jamb, I wouldn't hang an exterior door on it. The exterior jamb is stronger and will support the heavier door better. Besides the difference in hinge size, some older interior pre-hung doors only came with two hinges and an exterior would require three. (The ones I tore out of my house had only two.) A pre-hung exterior door would be easy to install, and as Bob mentioned comes with all the appropriate weatherstripping and a threshold to seal it tightly.....
Mop in Hand 01-18-2010 12:28 PM
Exterior doors are normally 1 3/4", while interior doors are 1 3/8" thick. The stops would have to be moved.
