Extending MBR Over Garage - Quick ? - Remodeling - DIY Chatroom Home Improvement Forum
Old 12-10-2010, 09:32 PM   #1
Extending MBR over garage - quick ?
My garage has a truss roof with the joists 24" apart. I had the idea of putting a closet space in the garage roof void - i assume it would require that the flooring be supported by more than just these joists ? I haven't opened up an access to this space to look more closely...
Conceptually, the idea is simple: put a door between the mbr and dead space over the garage, put down flooring and rock walls and its good to go. Somehow i doubt its that easy
Thoughts?
Bob
orcusomega is offline   Reply With Quote
Old 12-11-2010, 08:15 AM   #2
Rewards Points: 5,336
How much different is the garage floor joist system then the rest of the house?
Ron
Old 12-11-2010, 08:56 AM   #3
The rest of the house is 16" on center i believe. My neighbor has the same model home and they have this already (done at time of original construction) - frankly it seems very very easy - my only concern is the floor. Anyone know off hand what the requirements for flooring would be under IRC 2009? The space is currently dead space over the garage and would be a very (relatively) easy project... That would be something i could do over the holiday vacation pretty inexpensively...
Wow, this home improvement thing is addictive
Bob
Old 12-11-2010, 03:59 PM   #4
Rewards Points: 6,652
You would need at least minimum a 2x10 flooring frame, since you just can't place a room on a truss system that is not engineered for that amount of weight. It would be like placing a full size car with five occupants up in the attic of your garage. Sooner or later the car will fall through.
Old 12-11-2010, 08:54 PM   #5
Thanks for the reply - I came tothe same conclusion digging around as well. I am going to go down and get a copy of the plans for my house when i file the permit for the basememt. Thia way i have a better idea of what is in there without having to cut it open tk see where i could put in the floor joists.
Thanks!
Bob
The 12-Gauge Garage Jack Olsen Project Showcase 28 07-08-2012 10:21 PM
Extending the front of my garage by 3-5', how major of a undertaking is this? Kevin993 Off Topic 3 07-24-2010 02:27 PM
Raising up my garage jimmyfloyd Building & Construction 5 09-17-2009 10:39 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 02:57 PM
Extending an existing concrete garage base alan tomlinson Building & Construction 2 10-28-2008 02:26 PM
