Expansion Of Porcelain Tile On Bathroom Backerboard Flr And Walls? - Remodeling - DIY Chatroom Home Improvement Forum
Old 08-06-2011, 08:49 AM   #1
Expansion of porcelain tile on bathroom backerboard flr and walls?
Hi, I have a 6' x 7' bathroom that I am remodeling. I have backerboard on the flr and also going up 42" on the walls. I am about to lay porcelain tile on the backerboard flr and walls.
Question: is there an expansion issue to consider? TI was surprised to hear the guy at the hardware store who said to leave 1/4" space between the flr tile and the wall for the porcelain tile expansion. I guess the wall tile might have the same issue, leave 1/4" between the bottom of the wall tile and the flr? That kind of does not make a lot of sense, that would leave a space between the wall and flr tiles. I would want to have them butted up against each other and grouted and or sealed at that 90 degree intersection.
Thanks for any insights!
dvarga is offline   Reply With Quote
Old 08-06-2011, 09:55 AM   #2
NACE Coating Inspector
mustangmike3789's Avatar
you should have a flexible expansion joint where two different surfaces intersect. i dont think that you will need 1/4" in a room that small 1/8" should be good.
mustangmike3789 is offline   Reply With Quote
Old 08-06-2011, 12:24 PM   #3
thx
thx, will do that..
-D
Old 08-06-2011, 12:55 PM   #4
Experienced
Jackofall1's Avatar
You should not grout the connection between the wall the floor, use a siliconized acylic grout caulking, which can be purchased where you get your grout.
Mark
Old 08-06-2011, 04:04 PM   #5
Thx much
Thanks, will do that as well..
-Dave
_________________
Yes it works in practice, but will it work in Theory?
Old 08-08-2011, 10:12 PM   #6
Rewards Points: 5,336
"Porcelain tile expansion" is a nonsensical phrase. It (tile expansion) does not exist.
I'd leave an 1/8" gap at the floor and caulk it.
Before you tile the floor, tell us about the floor support and cement board attachment.
Ron
B. Franklin 1759
