Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 11-03-2012, 12:48 PM   #1
Exhaust vent question
Not really sure where to post this..
1. I have vinyl siding with vinyl soffit as well. I'm remodeling my bathroom and my old exhaust vent terminated behind the soffit . When installing my new exhaust fan and duct work is that acceptable to terminate it behind the vinyl sofft so that it's hidden? or do I need to have it actually terminate at the vinyl soffit.
2. Also, I have two bathrooms next to each other and both of the duct work exit in the same area. Would it be okay to tie them together near the end and have them exit out one vent or no?
Thanks.
REXAMUS is offline   Reply With Quote
Old 11-03-2012, 12:58 PM   #2
It needs to be ran all the way outside not just close to it.
http://www.amazon.com/Lambro-143W-Un...s=soffit+vents
A better way would be to vent it out the roof.
And no you can not just connect them together.
Old 11-03-2012, 01:15 PM   #3
Yea, I'm starting to lean towards the roof option since the air would just reenter the soffit.
Old 11-03-2012, 03:00 PM   #4
No, it wouldn't. Bathroom exhaust fans have a flapper at their outlet so air or wind can't come back into the room.
Soffit venting is preferred. With roof venting, moisture can condense in the vent line and drip back into the room.
Old 11-03-2012, 04:42 PM   #5
I was referring to the actual vinyl soffit. What's going to prevent it from exiting the vent and then rising straight back up into the attic through the vented soffit?
Old 11-03-2012, 05:11 PM   #6
GBrackins's Avatar
what does the exhaust fan manufacturer's specifications say?
this is what the 2009 International Residential Code requires:
R303.3 Bathrooms. Bathrooms, water closet compartments and other similar rooms shall be provided with aggregate glazing area in windows of not less than 3 square feet (0.3 m2), one-half of which must be openable.
Exception:
The glazed areas shall not be required where artificial light and a mechanical ventilation system are provided. The minimum ventilation rates shall be 50 cubic feet per minute (24 L/s) for intermittent ventilation or 20 cubic feet per minute (10 L/s) for continuous ventilation. Ventilation air from the space shall be exhausted directly to the outside.
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Yet another ridge vent question. ECB ESQ Roofing 5 05-31-2012 11:00 PM
Rheem white powder near exhaust vent? mikebau HVAC 21 03-29-2012 08:35 PM
Gas furnace exhaust vent question nowell HVAC 7 01-30-2012 09:31 AM
Two bathrooms, one exhaust vent? nettak Remodeling 2 05-27-2011 09:54 AM
Wrong roof vent for bathroom exhaust? vanishingson Roofing 18 04-04-2011 07:25 AM
