Exhaust Fan Question - Remodeling - DIY Chatroom Home Improvement Forum
Old 12-13-2012, 01:16 PM   #1
I am remodeling a bathroom and am changing out the exhaust fan. When I removed the old fan, I found that it was vented directly into the attic. Is this a normal way to install an exhaust fan??
arbfln is offline   Reply With Quote
Old 12-13-2012, 03:27 PM   #2
GBrackins's Avatar
Rewards Points: 2,108
exhaust fans should be vented to the exterior of the dwelling. should you be located in a cold climate moist air vented into the attic will accumulate on the framing and underside of the roof deck where it will freeze. when it warms up it will melt and drop back onto the ceiling and anything below it.
Also depending on your building code it is typically a code requirement to vent to the exterior.
read the manufacturer's installation instructions on your new fan and see what they say.
hope this helps! Good luck!
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
The Following User Says Thank You to GBrackins For This Useful Post:
arbfln (12-14-2012)
Old 12-13-2012, 03:30 PM   #3
Items wanted: Time
Rewards Points: 150
Moist air in the attic will grow mold, seen it too many times, including my home when I bought it.
NiNe O is offline   Reply With Quote
The Following User Says Thank You to NiNe O For This Useful Post:
arbfln (12-14-2012)
Old 12-14-2012, 10:35 AM   #4
Smile
I wish I would have known about the fans (two bathrooms) being vented into the attic years ago as we have lived here for 14 years. I would have corrected it then. No visible damage, so I think I'm OK. Thanks for the responses. This is a very helpful forum!!
Question about my exhaust vent over stove jpc Roofing/Siding 8 07-15-2012 08:59 AM
Can I T (connect) my dryer exhaust with my stove exhaust shd1998 HVAC 3 06-21-2012 09:52 PM
exhaust fan for bathroom question MLMIB Kitchen & Bath Remodeling 1 05-18-2012 02:34 PM
Yet another bathroom exhaust fan venting question JulesB HVAC 23 03-10-2011 03:16 PM
Dryer exhaust question KC Brick Layer Plumbing 3 12-08-2008 08:47 AM
