Entainment center - ceiling differs 1.25" inches side to side - what to do?
1 Attachment(s)
Entertainment center construction in process. Wall to wall - floor to ceiling. Come to find out the ceiling is 1.25" lower on one side (right side) than the other - how best to deal with this?
Crown molding will extend from around the room and run across the top front of the entertainment center. There is a 1x4 trim board across the top of the entertainment center. Obviously these need to be parallel - else the reveal between the crown and the trim board will plainly show the difference. The concrete floor is level. The cabinet base is level. The top of the cabinets is level. The shelving is level. The ceiling is out of wack... The cabinet boxes are already built as in the picture. And the picture was during work in progress. The problem was not realized until most everything is assembled and in place. Suggestions? |
You can scribe the top edge of the trimboard to the ceiling and still have the bottom edge level with the cabinet tops (you may need a wider board for this). I don't see a way to run the crown across it, though, because you can't scribe the profile. May have to have the crown die into the sides of the cabinets rather than go across.
Usually you can skim coat an out of level wall or ceiling, but not by over an inch. Sorry, I can't think of a better idea. |
I really wanted the crown to run across the top - but eliminating it there is an idea to consider. However, I am still concerned that the difference is great enough that it will still be apparant in the trim board...
We are considering to tilt the top trim board to run parallet to the ceiling, and apply the crown. This would make the trim board overlap the top of the cabinet more on the one end than the other. Input on how anyone thinks this will look is welcomed. |
Take the sheetrock off the ceiling and rework the framing to level. You may just have to do about 4' or so and feather it into the ceiling. Depends if the situation is throughout the ceiling.
Ron |
It will be obvious to you because you did the work. Most won't notice. Did your eye notice before starting the project?
I'm guessing that you want to attach the crown to the front of the existing top piece. Obviously, the crown will be perfect on one end and below the top on the other. If you put a wide piece of trim at the top that overhangs the front of the box and then attach the crown to it, it won't be as noticeable across that distance. |
The house is 25 years old, a 1800 sq ft single story ranch rectangular box measuring 30'x60'. The ceiling is the bottom cord of trusses that span the 30" depth of the house (and parallel to the new entertainment center). Evidently the bottom of the trusses was not flat and the interior walls were built accordingly? |
Furthermore,
you could use that front trim piece to cut that gap in half. Again, no one but you will be able to tell the trim piece isn't perfectly level. If you have a 2" reveal at one end, you could easily get away with a 1.5" reveal at the other. |
1 Attachment(s)
The previous picture was a work in progress - here is an updated picture. The ceiling issue was not realized until after the entertainment center was nearly completed...
How wide is the face frame at the top? How big will the reveal be once the crown in attached?
I am kinda liking the idea of a wider board at the top - overhanging and cut to reduce the difference - and then to see if the casual viewers eye would not readily pick out the issue. |
Frankly, I think the most obvious "out-of-level" area to spot anything will be that long, straight run at the ceiling. It's not wide (tall) enough to fool the eye. I'd try to get that part pretty close. All the stuff on the shelves will break up visual continuity in those short runs, but not at the ceiling. Remember, books are usually all different heights, and plants, knick-knacks and angled photos throw off the eye anyway.
I would split the 1-1/4 up in several places... just a little in each.
finished
1 Attachment(s)
Thanks everyone for all the great suggestions!
Here's a picture of what was done to fix it. The top board was dropped/tilted a bit at the left side (cutting each verticle stile a bit) and the crown was spaced a bit from the ceiling on the right side. While there is still a small difference, it is not readily noticable - and then only if you know to look for it. Now to spend some time this weekend to prime and paint. And to buy a big LCD TV to fill in the middle! :thumbup: Again - thanks to all for great support! Vince |
Nice job. I like it. :thumbup:
Oh Geez! I can see the problem all the way from chicago. Gotta tear it down and start over. Ha hA.
looks great! I am planing on doing the exact same thing. Give us a little detail on how you constructed it. |
1 Attachment(s)
The front of the 12" deep cabinets are spaced out from the wall about 20" - the cabinet top sits directly on the cabinets with a ledger board along the wall to provide support at the rear. The cabinet top is plywood with a rope trim to finish off the front edge. As you can see from the the earlier in-progress picture the uppers are basically three boxs made from MDF. 1x2 hardwood pieces are used to create the face frame. The crown from around the room extends across the top of the unit. The entire unit will be primed, then finished with white SW waterborne enamel to match all the crown, casings, and base in the rest of the ajoining areas. The overall width is 163". The center section is sized to fit a 52" LCD Television which will be floated on a wall mount. Appropriate holes and openings are made to allow for cables, power cords, etc. |
| All times are GMT -4. The time now is 11:35 AM. |
