Enlarging Living Room Entrance - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-14-2012, 08:09 PM   #1
Rewards Points: 83
Enlarging living room entrance
I'm about to enlarge the opening to my living room by about 18", but before I do so I wanted to do a quick sanity check. The existing opening does not have a header, it is just framed with cripple studs. This means that the wall is not load bearing, correct?
I think the ceiling joists run parallel to the wall, but I will double-check.
Thanks,
Mark
cumak is offline   Reply With Quote
Old 01-14-2012, 08:13 PM   #2
Rewards Points: 13,694
How about a picture, I've never seen a nonbearing outside wall.
Old 01-14-2012, 08:19 PM   #3
Rewards Points: 83
Sorry if I was unclear. This is an interior wall. It's the entrance to my living room off of the hallway.
Old 01-14-2012, 08:31 PM   #4
MarginallyQualified
Rewards Points: 2,464
Not necessarily. The load supports could be in the wall to each side.
TRIPLE check.
Don't forget to check for HVAC and electric etc too
Old 01-14-2012, 10:39 PM   #5
Rewards Points: 6,652
Thanks,
Mark
Don't you mean 18 feet? 18 inches is not worth the hassle.
Old 01-14-2012, 11:04 PM   #6
Rewards Points: 83
Originally Posted by TarheelTerp View Post
TRIPLE check.
And if the joists do in fact run parallel to the wall then I'm all set?
No, just 18 inches.
Old 01-15-2012, 07:38 AM   #7
cumak, it is not even worth the effort, to get that little extra.
Old 01-15-2012, 07:44 AM   #8
Ole Wood Worker
BigJim's Avatar
Rewards Points: 386
If OP is trying to get a wheel chair through the door it would be.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
The Following 2 Users Say Thank You to BigJim For This Useful Post:
Jay 78 (01-15-2012), oh'mike (01-15-2012)
Old 01-15-2012, 07:49 AM   #9
MarginallyQualified
And if the joists do in fact run parallel to the wall then I'm all set (to assume that the wall is NOT load bearing?
Probably so. But I'm not there to see.
There's a limit to what can be asserted online and by description.
All posts have this warning implied...
Old 01-15-2012, 08:28 AM   #10
There is no way of telling, due to this information is not there. The smallest entrance you can get a wheel chair through is 32", 36" is just the standard for ADA, but not necessary in a home. My front door is 36", most are 34", which is just enough.
There really is not enough info as to why they want to only go eighteen inches, and from the fact, that they did not state that it was a doorway, but a entrance to a room, which I am taking is just from another room, not from the outside.
Old 01-15-2012, 08:36 AM   #11
Rewards Points: 150
How about every gable ever built.
OhioHomeDoctor is offline   Reply With Quote
Old 01-15-2012, 09:01 AM   #12
Rewards Points: 2,212
Usually true but not always. One example wood be a balloon framed gable. Or if for some reason 2nd floor joists are running perpendicular to the gable, not usually but in renovations and old houses weird things happen.
mae-ling is offline   Reply With Quote
Old 01-15-2012, 09:05 AM   #13
Rewards Points: 83
No, this isn't an ADA thing or anything like that. It's purely aesthetic. But, I already have to repair drywall and paint the room, and put down new flooring, so enlarging the opening really isn't that much additional work. It's hard to explain, but the extra 18" will give the room a much more open feel and bring natural light into the hall.
I think I'm going to do it based on this:
- The house is a colonial style
- The main support beam for the floor above, as expected, runs along the middle of the house in the same direction as the ridge line of the roof.
- The wall in question is perpendicular to this beam. Same as the ceiling joists.
- The original builder did not put a header above the existing wall opening, and after 40 years the wall is still in good shape.
I know nobody can say with 100% certainty without seeing plans, but this really seems to be a non bearing wall.
Old 01-15-2012, 10:16 AM   #14
Framing Contractor
Wow!...gotta love the internet. That is not true at all. Obviously you haven't done much framing to say that. This is a perfect example of false and dangerous information.
Joe Carola
Joe Carola is offline   Reply With Quote
The Following User Says Thank You to Joe Carola For This Useful Post:
loneframer (01-15-2012)
Old 01-15-2012, 01:01 PM   #15
KemoSabe
loneframer's Avatar
There are so many scenarios that could make that a bearing wall that nobody should assume it is not.
Even if the joists run one direction in one room, they could easily change direction in the next, due to a number of circumstances. The fact that there is not a dropped header in the wall does not mean there is not a flush header above the plates. There could be a flush header with a single point load bearing on the center of it and removing structure from one side or the other could create problems.
Assumptions should never be made without thorough investigation of field conditions.
It's not that it took him an hour to make 100 bucks, it's that it didn't take you 10 hours to save 100 bucks.
loneframer is offline   Reply With Quote
The Following 2 Users Say Thank You to loneframer For This Useful Post:
cumak (01-15-2012), mae-ling (01-15-2012)
Need help decorating living room please! Megahmom Interior Decorating 2 10-19-2011 12:04 PM
what is the best type of recessed light to have a bright living room scupit Interior Decorating 1 07-16-2011 10:37 PM
Choosing colors for painting living room, kitchen Bugpals Painting 2 05-15-2009 09:19 AM
Smoke detector - Living room with FP and fan ><(((jan(((D> Safety 42 12-28-2007 08:59 AM
wooden balcony in living room Lorac Building & Construction 1 07-24-2004 03:33 PM
