Enlarging Cooktop Cutout In Tile Counter - Remodeling - DIY Chatroom Home Improvement Forum
Old 11-02-2007, 11:24 AM   #1
Enlarging cooktop cutout in tile counter
Hi,
I am new to the forum and need a bit of advice.
I need to enlarge the cutout in my tile counter to accomodate a new cooktop. The countertop is hard ceramic tile on cement board on plywood. The cutout is now 34x18 1/2 and it I need 33 7/8x19 1/8 for the new cooktop. All the cooktops we've considered need over 19" in width.
I plan on getting a 7" dry diamond blade for my circular saw and I may need a diamond cup blade for my grinder to finish in the corners.
Am I on the right track here?
Thanks,
glenmore
glenmorenee is offline   Reply With Quote
Old 11-02-2007, 01:55 PM   #2
Sure that will work...but
Sure that will work. Build a plastic room around you and go for it. Or you could Wetsaw the ceramic and then cut the rest with a circular saw. Or you could pop out the ceramic carefully. If you had extra tiles I would say you could take the tiles out around the existing hole then cut the wood and then put new tiles in. Probably could come up with options if I think about it. Got to Go!
localtradesman is offline   Reply With Quote
Old 11-02-2007, 10:13 PM   #3
Rewards Points: 5,336
If you use the circular saw, cover the tile to protect in from scratches from the saw's plate. Have a helper hold a shop vac close to the exhaust.
Personnaly I would use a grinder for the whole job of the tile and cement board and a jigsaw for the wood.
Ron
Tile over Tile ?? Piney Flooring 17 02-06-2012 09:59 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 03:31 PM
Granite tile counter question ryguy Flooring 3 09-27-2007 11:31 AM
Some questions about laying Tile? DiY_RooK Flooring 1 08-31-2007 09:35 PM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 02:14 PM
