Ending Baseboard Next To Open Space - Remodeling - DIY Chatroom Home Improvement Forum
Old 11-19-2011, 01:37 PM   #1
Rewards Points: 33
Ending Baseboard next to open space
I am remodeling my bed room and installed new floor.
I am about to install baseboard and would like to ask for advice.
I have a open closet into the wall. How do you end the baseboard in this case?
Can I use baseboard or I should fill in the gap with wood or dry wall?
I apologize if I didn't ask my question clearly.
Here are the pictures:
cfreak is offline   Reply With Quote
Old 11-19-2011, 09:10 PM   #2
There are several ways to end baseboard. The first is you just mider a 22.5 or 45 degree inside cut and end it like that. Second, you could mider a 45 outside cut and then cut a 45 sliver piece that ends at the wall. Be careful cutting that tiny piece. Lastly, you can buy or build yourself end blocks to whatever shape or size you want, and the base board simple butts up to it. This might look odd if this is the only place you're doing it though. Hope that wasn't to confusing.
Stanchek is offline   Reply With Quote
Baseboard Gap Options? Installing Floating Vinyl Flooring Today. Please Help. skeeter505 Flooring 1 09-17-2011 07:46 AM
Better to cut batts than scrunch them to open up space at rim joist? darlingm Insulation 2 08-30-2011 12:26 PM
Crawl space moisture/water removal KAdams4458 Building & Construction 7 04-24-2011 12:21 PM
Installing some baseboard across 2 different floor types? BigJohnny Building & Construction 9 08-03-2010 11:41 AM
Tile baseboard with carpet? bpak04 Flooring 2 11-03-2008 12:28 PM
