Electrical-well - Remodeling - DIY Chatroom Home Improvement Forum
Old 08-26-2013, 01:23 PM   #1
Question
electrical-well
I would like to know if I can remove the wires from the pressure switch (220V) and put a junction box and splice the wires together so that I can have the power a sub-panel at the well and install everything the bladder, pressure switch, and controller all at one location along with a 110v outlet. Currently at the well is the controller and at the house is the bladder and pressure switch and main panel.
Also would I need to put a ground rod?
1cashking is offline   Reply With Quote
Proper way to ground a subpanel chieftaing Electrical 25 04-03-2011 10:22 AM
Electrical Questions from a Foreigner mark_anderson_u Electrical 4 09-10-2010 06:46 AM
For stacked dryer/washer - where to locate electrical outlets and water supply lines Cliffhanger Electrical 3 09-05-2010 09:48 AM
Electrical Panel Upgrade & Main Water Shut Off DIYerIT Electrical 2 09-02-2010 02:42 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
