Durock On Studs, Durock Screws - Remodeling - DIY Chatroom Home Improvement Forum
Old 06-12-2007, 08:05 PM   #1
weekend warrior
Rewards Points: 150
durock on studs, durock screws
Does cement board go right on the wood studs in a bathroom? Or does it require some sort of backing/underlayment? Is there any sort of vapor barrier used for the walls/floor?
Everyone says to use special durock scews, I've never seen them (never really looked hard)... Can I get them anywhere?
johnny331 is offline   Reply With Quote
Old 06-12-2007, 11:00 PM   #2
Rewards Points: 5,336
Cement board over a 6 mil vapor barrier directly into the studs. The screws are in the same aisle(HD) as the sheetrock, durock, corner bead, etc... You can also use roofing nails.
Ron
Old 06-13-2007, 05:49 AM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Already answered.
No.
Already answered.
They are often in the Tile materials/tools area of the BIG HOME stores.
Also try tile suppliers.
Example:
http://www.cgcinc.com/pdf/datasheets/EDR_6294.pdf
FWIW: Duraokc installation guide:
http://www.cgcinc.com/pdf/install/EDR_00D6_web.pdf
- Build Well -
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 08:50 PM
I can't get tapcon screws to tap into the concrete slab!? Monty Building & Construction 24 08-07-2010 07:08 AM
nails and staples missed studs in garage dingler44 Building & Construction 1 10-10-2006 11:10 PM
Screws vs Nails in Interior framing project alexz Building & Construction 2 07-05-2006 05:58 AM
How to line up trusses with studs aero_ub Carpentry 5 04-24-2006 03:48 PM
