Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 06-11-2008, 10:50 PM   #1
Question
Durock or Green Board
Hello, I have a question. I am remodling my shower/Bathroom and was going to tile the that I had just installed. Anyway, I had installed Durock on the back wall so far but it doesnt quite reach where I wanted to stop tileing (12"short). I was woundering if I could use green board instead of adding more durock to make up the diference of the 12" since im using green board above the window anyway? Or should I add the durock?
Thanks!
oxicottin is offline   Reply With Quote
Old 06-11-2008, 11:45 PM   #2
K&B Remodeler/Tile Guy
angus242's Avatar
Should I assume you meant tub surround?
If so....(here I go again )
What about waterproofing? Tile and grout are not impermeable to water. Durock is NOT waterproofing. If you don't waterproof, mold or tile failure is in your future. A quick fix to your situation is to buy some RedGard. It is a liquid membrane that you paint over what you are going to tile. In this case, you would be able to finish your walls with wall board and just paint the RedGard over it. Problem solved.
Also, greenboard is an old, outdated material. It has no benefit. If you want a material that's useful, try DensArmor. It's mold resistant.
Good luck
Angus
My Albums
angus242 is offline   Reply With Quote
Old 06-12-2008, 05:40 AM   #3
Hello, The board Im using is USG mold resistant board that is green this is for the walls in the bathroom im going to paint but around the tub that im going to tile im using Durock. I guss Im concerned that it wont stick to the board the same as the Durock if I tile to it? Or is it Ok? I am going to look into that RedGuard stuff...
Thanks!
Old 06-12-2008, 06:07 AM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Simple answer to the question: Tile will stick to any kind of sheetrock. If you have an area that will be directly affected, or is directly adjacent to, a shower, or high moisture area, I suggest that you use a cementitious board for your tile work.
As covered by Angus: MR (aka green board) is a product that is rated as Moisture (vapor) resistant. It is not moisture (direct water contact) resistant. It is also a very old and outdated product that has been superceded by much more advanced wallboard materials such as Densarmor (paperless and truly mold resistant wallboard) or XP board (the new paper-faced MR board - purple, mold resistant paper - with a mold resistant core)
I do not suggest that either of these be used as a tile substrate surface, in wet applications (shower area/tub wall). However, the material is practical in it's use in other areas of a bathroom or in basement remodeling (finishing) projects.
Links:
Densarmor: http://www.gp.com/build/product.aspx?pid=4659
National Gypsum XP Board: http://www.nationalgypsum.com/products/product69.aspx
- Build Well -
Old 06-12-2008, 10:03 AM   #5
angus242's Avatar
Yes, by all means, Durock is your PREFERRED backer. However, for the last few inches of your wall, IF and only IF you use RedGard, you'll be OK. If you can get Durock up there, use that.
Don't just "look into that RedGard stuff". BUY IT! It is usually sold at Home Depot.
Waterproof your surround and be done with it! RedGard is made to be tiled over.
Good luck
Angus
My Albums
Old 06-12-2008, 03:32 PM   #6
Well I am going to purchase the RedGuard and I will apply the Durock to the heigth I was going to But I cant find any info on the material? I looked threw home depot and couldnt find it also, I only use USG products because I make the paperfaced cornerbead! so I will have to deal with the stuff I had purchased....
Thanks for the advise and sugestions!
Old 06-12-2008, 05:46 PM   #7
angus242's Avatar
http://www.custombuildingproducts.co...s/RedGard.aspx
http://www.homedepot.com/webapp/wcs/...0&ddkey=Search
Angus
My Albums
Old 06-12-2008, 07:51 PM   #8
Thanks very much! I was spelling it wrong. I was spelling it RedGuard
Thanks again!
More On This Topic
The drywall you choose for your next home improvement project depends upon the room in which you are planning to work. Drywall, often referred to as wallboard, is available in different varieties, lengths and widths. Here's how to choose drywall for your... Read More »
Hi! My name is Andy Strohl and on behalf of Expert Village, in this clip we will be discussing how to arrange our tiles and actually get them on the board to form words on the board game, Scrabble. Don’t forget to check out my work at www... Read More »
Carcassonne is a popular German-style (strategic, tile-based) board game that was released in 2001. The object is to build the most efficient and effective landscape around the central town (Carcassonne). There is a lot of strategy involved in the game... Read More »
I'm Tom Shean and today on behalf of Expert Village I'm going to show you how to install a metal roof. In this instance a minimum two courses of lower roof panels are laid through. If possible with continental tiles, lay it out so that the lower part of... Read More »
While wicker furniture is highly prized for its durability and timeless style, it is still made of wood, and the many cracks and spaces in the material make it more susceptible to mold than other types of furniture. Preventing and removing mold will make... Read More »
Preping green board for tile? stbo2000 Remodeling 9 02-06-2008 10:40 AM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 11:50 PM
Green board/ good or no? fqp25 Building & Construction 7 09-06-2006 07:37 PM
Ruud a/c control board replacement ? kourso HVAC 1 07-20-2006 10:33 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
