DUROCK Cement Board For Exterior Walls - Remodeling - DIY Chatroom Home Improvement Forum
Old 12-25-2013, 05:52 PM   #1
Rewards Points: 35
DUROCK Cement Board for Exterior Walls
Hello,
can I use the cement boards for the exterior walls?
I would like to replace the vinyl siding and the plywood underneath with the cement board.
I read a little bit that it is possible, but not on how it is done right.
Anyone with good advices?
Thank you
MAD King is offline   Reply With Quote
Old 12-25-2013, 08:53 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,554
It can be done. Why are you thinking of that route first?
Old 12-25-2013, 09:03 PM   #3
Rewards Points: 35
I like to have the wall a little bit more sturdy and would like to paint it.
And I hate vinyl siding.
Old 12-25-2013, 10:04 PM   #4
Gymschu's Avatar
Rewards Points: 1,024
Why not leave the sheathing and install Hardie planks for siding. It's great, durable stuff that would be better than cement board. The problem with something like cement board on the exterior is making joints water tight.
Gymschu is online now   Reply With Quote
Old 12-25-2013, 10:34 PM   #5
Rewards Points: 35
Because they still look like vinyl sidings.
I want a flat surface and planks do have these interlocking look too.
Old 12-26-2013, 07:08 AM   #6
Rewards Points: 3,130
Gonna be pretty expensive - cement board doesn't come in 4x8 sheets like plywood and OSB. And, believe it or not, moisture will deteriorate the stuff. I had some scraps of Durock lying in the yard and in a couple years they just fell apart.
The Following User Says Thank You to md2lgyk For This Useful Post:
woodworkbykirk (12-26-2013)
Old 12-26-2013, 07:55 AM   #7
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,334
exactly,, the durock on its own isnt water proof.. consider harti panel instead of harti plank. even still its going to be very expensive. with harti panel you frame the walls the normal way and then install house wrap.. from there the harti panels get hung off the wall . if you want a smooth surface consider just going with dryvit
woodworkbykirk is offline   Reply With Quote
egads, do I need to rip out my cement board and start again? soberjulie Flooring 38 06-28-2013 10:27 AM
how to install cement board for tub walls and floor cantonstf Remodeling 1 11-26-2012 07:50 PM
Cement Board Questions trophywalleye Drywall & Plaster 17 06-29-2011 10:56 PM
Cement board meets drywall? CowboyAndy Drywall & Plaster 8 12-25-2010 08:29 PM
cement board install billyg Flooring 2 07-10-2009 12:52 PM
