Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 07-09-2006, 10:00 AM   #1
Durarock for walls in flood zone?
We were recently flooded with Alberto and had to remove our drywall. We are thinking of using durarock with plaster to flood proof for future........does this make sense?
Jo Anne Coop is offline   Reply With Quote
Old 07-09-2006, 04:49 PM   #2
Construction Estimator
No it will not flood proof it. It (the Durock) will withstand water for sure, but the plaster or any other interior finish will not stand up to flooding. There is really nothing you can do to prevent problems with flooding other than moving yourself or your house to higher ground. Also you will have problems with water getting behind the walls and molding as well. I feel for you, and know you would really like a solution to your problem as your house now sits but the reality is there is no solution where you are located. I'm glad to be on higher ground here in Apopka for sure.
DaveH is offline   Reply With Quote
3 zone thermostat moggi1964 HVAC 7 02-02-2012 11:21 AM
Zone system not working with heat. deliriousga HVAC 5 12-29-2006 07:04 PM
Halogen flood lights chicagonyc Electrical 5 07-15-2006 11:11 PM
