Dura Rock - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-19-2014, 08:19 AM   #1
dura rock
im tiling my bathroom and did it all in green board then found out that it is not code for aparant reasons . can i go over the green dboard with 1/4 inch dura rock or does it have to come down
henry1 is offline   Reply With Quote
Old 01-19-2014, 07:31 PM   #2
DIY staff
Rewards Points: 7,174
It needs to be remove in the 'wet areas'---shower /tub surround---any where that is not subject to water --your green board can stay.
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
henry1 (01-20-2014), Windows on Wash (01-20-2014)
Old 01-20-2014, 09:27 PM   #3
Registered User
Rewards Points: 526
Unless you used 1/2" thick on the ceiling and joists are more than 12"oc. Or you installed any faced batts or poly under the drywall; http://publicecodes.cyberregs.com/ic...9_7_par016.htm
Gary
PS. Welcome to the forums!
Old 01-23-2014, 06:12 PM   #4
Rewards Points: 150
What if he put durok over it and then red guarded the durok?
Arsinek is offline   Reply With Quote
Old 01-24-2014, 06:52 PM   #5
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,334
the durock has to get waterproofed no matter what. but by going over it they would have to add another layer of green board so its in the same plane as the durock .. thus keeping hte wall flat
woodworkbykirk is offline   Reply With Quote
Dura rock finishes rmccombe General DIY Discussions 1 05-30-2013 01:18 AM
installing dura rock in shower + prefab shower pan Pcw Kitchen & Bath Remodeling 0 09-25-2010 01:39 PM
Installing dura rock over tub lip bitsy01 Plumbing 4 02-25-2010 11:29 AM
Building a deck on solid rock time2scream Building & Construction 3 03-05-2009 07:45 PM
Concrete driveway with rock salt finish? imola ghost Building & Construction 11 10-27-2008 12:11 AM
