Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 10-31-2012, 09:17 AM   #1
ductwork through wall
Can someone tell me the proper way to seal ductwork going through an exterior wall? I am venting a microwave oven through the wall (wood siding). They hole is a bit bigger than the duct and I'm not really sure what you put around the duct pipe to hide/seal that gap.
I've looked at the big box stores and didn't see anything specific for this. Would you just use a flat piece of flashing material, cut a hole as close to the duct size as possible, nail that to the outside wall and chalk any remaining gaps?
Rut
rutledj is offline   Reply With Quote
Old 10-31-2012, 10:24 AM   #2
GBrackins's Avatar
check this out http://www.famcomfg.com/product-info/tag/wall-vents-2/
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 10-31-2012, 10:27 AM   #3
Not exactly what I'm looking for. I'm going through a wall (between kitchen and garage) and then straight up through roof. I need to pretty up (and seal airtight) the area where the duct comes through the wall on the garage side.
Core filling a bowing wall, please assist silverstrike Building & Construction 12 06-16-2012 11:28 PM
plastic ductwork vs. metal: acoustic duct liners jjpclev HVAC 5 02-26-2010 08:29 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
