Drywalling Without Taking Down A Drop Ceiling - Remodeling - DIY Chatroom Home Improvement Forum
Old 08-13-2012, 01:24 PM   #1
Question
Drywalling without taking down a drop ceiling
I currently have a large bathroom in my efficiency apartment that has your standard drop ceiling and the walls are old plaster and lathe covered by old warped panel board. I would like to tear down the panel board and put quarter inch drywall over the plaster and lathe to create a new service. However, the problem will be how to incorporate it into the drop ceiling. Is there an easy solution? Or must I take the drop ceiling down and then put it back up on top of the new surface? Suggestions appreciated. Thanks!
Tljank is offline   Reply With Quote
Old 08-13-2012, 08:30 PM   #2
Rewards Points: 236
you could put the drywall up to the drop ceiling. and put some kind of trim to cover the gap. but if some one looks at it, they could tell its not done right. but, it could still look ok.
Fix'n it is offline   Reply With Quote
The Following User Says Thank You to Fix'n it For This Useful Post:
mae-ling (08-14-2012)
Old 08-14-2012, 10:18 PM   #3
If it's just a bathroom, it really wouldn't take a lot of time to carefully remove the ceiling and put it back up when finished. It may seem like more work however it would make the boarding and mudding much easier. Better yet lose the drop ceiling altogether.
chrisBC is offline   Reply With Quote
Tags
drop ceiling , drywall
Removing Drop Ceiling in Bathroom ashton44 Kitchen & Bath Remodeling 0 04-04-2012 11:44 AM
Drop Ceiling removal alewiska Remodeling 14 12-12-2011 04:05 PM
Basement - drop ceiling jgrohol Building & Construction 11 04-01-2011 12:39 PM
Drywall or Drop Ceiling HooKooDooKu Drywall & Plaster 19 12-21-2010 12:39 PM
How do you convert a drop ceiling to a normal ceiling??? acoustic_bum Remodeling 8 01-16-2007 10:55 PM
