Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 12-27-2007, 10:16 PM   #1
Drywalling over Shower Surround nailing flange
What is the best way to drywall over the flange of the shower surround? I've tried to just drywall over it, but the edge of the drywall keeps breaking because of the thickness of the flange (1/8 inch). This problem is really holding up the completion of my bathroom remodel. Thanks for any help!
dylanm is offline   Reply With Quote
Old 12-28-2007, 12:03 AM   #2
Shim out the studs with shims or thick paper, or whatever, so the drywall has a fairly even surface under it.
NateHanson is offline   Reply With Quote
Old 12-28-2007, 08:20 AM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
As stated already...
Rip down "lathe" type "strip-shims" that are the same thickness as the shower flange thickness. It should be anywhere from 1/4" to 1/8".
Attach these onto any of the exposed rough framing areas that the nailing flange is not sitting on. Thus, "equalizing" the surface area thickness - of what you will be nailing or screwing your sheetrock onto.
Goo Luck...
- Build Well -
very low shower head flow rickard681 Plumbing 7 10-08-2008 07:43 AM
Another newbie building a tile shower ChadC Building & Construction 7 08-25-2008 03:58 PM
Drywalling around shower module Richo Building & Construction 5 12-09-2007 11:46 PM
Bathroom Shower Help - PLEASE :) OTEJUNK Remodeling 5 05-09-2007 11:33 AM
Flange Help Needed tajones44 Plumbing 2 07-11-2005 05:42 PM
