-   -   Drywalling over Shower Surround nailing flange (http://www.diychatroom.com/f15/drywalling-over-shower-surround-nailing-flange-14834/)
dylanm 12-27-2007 09:16 PM
What is the best way to drywall over the flange of the shower surround? I've tried to just drywall over it, but the edge of the drywall keeps breaking because of the thickness of the flange (1/8 inch). This problem is really holding up the completion of my bathroom remodel. Thanks for any help!
NateHanson 12-27-2007 11:03 PM
Shim out the studs with shims or thick paper, or whatever, so the drywall has a fairly even surface under it.
AtlanticWBConst. 12-28-2007 07:20 AM
As stated already...
Rip down "lathe" type "strip-shims" that are the same thickness as the shower flange thickness. It should be anywhere from 1/4" to 1/8".
Attach these onto any of the exposed rough framing areas that the nailing flange is not sitting on. Thus, "equalizing" the surface area thickness - of what you will be nailing or screwing your sheetrock onto.
Goo Luck...
