Drywalling Over A Plank Wall - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-05-2009, 09:19 AM   #1
Drywalling over a plank wall
Howdy,
I am renovating an old homestead and was wondering if I can get away from strapping the walls. The walls may have a few dips in the wall so can I just not drive the screws completly in tight? any help would be greatly appreciated.
adamb is offline   Reply With Quote
Old 02-05-2009, 01:59 PM   #2
Drywall contractor
Rewards Points: 1,070
If the screws don't pull the drywall tight to the framing member (planking in this case) the first time any pressure is applied the screw will "pop". It could result from as little pressure as when you sand or roll paint on the wall. If the depression is sever enough, the screw will just pull through the board. You will need to shim any low spots to allow proper fastening.......
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Tags
drywall , strapping
Temporary wall support question discojv Building & Construction 7 01-25-2009 07:23 PM
How to diagnose problems with wall kahlan General DIY Discussions 5 10-22-2008 09:18 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
