Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 03-22-2009, 01:31 AM   #1
Drywalling my basement ceiling
Hi I am drywalling my basement ceiling. And have a question. I put up an internal wall and used perpendicular 2X4s to joists to attach my wall at the top. I should have put them between the joist instead of on top of them. Oh well mistake taken. Now in this one room I have a ceiling at 2 different heights... drywall attached to the joist all the way down. then the last Aprox. 18 inches the I have those 2X4s on the joists... so the last 18 inches the ceiling drops 1.75 inches for the 2X4.
My question is.. any suggestion for the Transition?
Can I just cut a 1.75 inch piece of drywall 9 foot long (the lenght of the ceiling) screw it to the face of the 2X4s to connect the 2 different ceiling heights?
Pros have had to of dealt with this before. What do you guys do?
luweee is offline   Reply With Quote
Old 03-22-2009, 03:27 PM   #2
Drywall contractor
If I'm picturing this correctly in my mind, yes you would screw/nail a piece of drywall to the 2"x4"s and finish it with a piece of corner bead after you tape the angle....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 03-22-2009, 03:51 PM   #3
Remodeling Contractor
Taping the top angle between the ceiling and this small drop is what he is saying. Then add corner bead and tape that. Use "hot mud" not the premixed tub compound for the corner bead. It will dry faster and harder.
Old 03-22-2009, 10:20 PM   #4
Thanks bjbatlanta and BOB.
And I like your quote BJBATLANTA! 11 yrs Navy here Gulf 1 war veteran.
Thanks again!
Old 03-24-2009, 02:57 PM   #5
Drywall contractor
Thanks for your service to our country luweee!!! Got a boy in the Guard who spent his 19th birthday in the desert and going back soon for another deployment.
IF you don't stand behind our troops, feel free to stand in front of them....
Old 03-24-2009, 07:58 PM   #6
AMEN to that!!!!!!!!!!!!!!!!!
Five inch ductwork in basement ceiling - how to end the run? drnormie HVAC 5 11-25-2008 10:21 AM
Arch ways, columns and ceiling drops - basement cobase Building & Construction 3 09-01-2008 04:21 PM
Work lights in basement with drop ceiling fw2007 Electrical 2 10-20-2007 10:39 AM
Basement Ceiling- Combo of Drywall and Drop ceiling? H Thomas Building & Construction 5 03-27-2006 09:27 AM
