Drywalling A Ceiling - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-04-2006, 01:01 AM   #1
drywalling a ceiling
ok, I am in the process of finishing the basement of my cottage and am ready for drywall. I am told I should drwall the ceilings first. I am guessing this is to help support the ends of the drywall, but i don't really know.
My question is this. At the end of the cottage, the joists end off the walls. After my frameing is complete there is a 1.5 inch gap between the last joist and the wall frameing. So how do I go about drywalling this? Should I just secure it to the last joist, or must I add some wood and secure absolute end of the drywall? Basically, if I leave 1.5 inches of drywall after the last set of screws will this cause any trouble?
ty John
TorontoJohn is offline   Reply With Quote
Old 01-04-2006, 01:59 AM   #2
renovations
"Basically, if I leave 1.5 inches of drywall after the last set of screws will this cause any trouble?"
No, you're good to go.
Bonus is offline   Reply With Quote
Old 01-04-2006, 03:07 AM   #3
Hmmm ok, what if it's more, about 2-2 1/4 inches? Does it not make any difference aslong as it is held nicely throughout?
The cinder block walls are not square. eg. the length of the room is supposed to be 27 feet. It is 27 feet at one corner, however in the other it is 27 feet 1/2 inch. Now when I do the drywall will this cause any problems?
I am thinking of just making a control line with a chalk string line thing. That way I know it's straig and can fix the other parts later.
Old 01-04-2006, 05:08 PM   #4
Contractor
KenTheHandyMan's Avatar
Rewards Points: 150
If I understand what you are saying, I would take some 2x6 and lay them flat on the top plate of the wall. This gives you a nailer for the perimeter of the drywall. I know that 1 1/2" or 2 1/4" doesn't seem like much, but if you float it, there will be a weak spot and I think you'll see a crack after a few years.
That's the way I do it anyhow. I try not to float it if at all possible, and usually, it's possible.
BTW, you can cut the 2x6 into smaller pieces and leave gaps between each piece. This'll help you go farther with one board.
Regards,
Ken Walker
KenTheHandyMan is offline   Reply With Quote
Old 01-04-2006, 09:57 PM   #5
renovations
Ken's correct, it's better to have backing, but trying to get backing into a space 1-1/2" wide and then secure it could be problematical. You can 'scab' a 2x4 on to the side of the joist which will fill most of the space most of the way. This won't be attached to the wall, so Ken's worry about cracking will still be there, but I'd do it on my place and sleep soundly, with or without the 'scab'
Old 01-05-2006, 01:59 AM   #6
I know I will end up doing it, just so I Can...sleep better at night.
I am going to have to pull out that tyvex stuf to get at the baseplae though:| always more work:p
Old 01-05-2006, 02:49 AM   #7
Carpenter
DecksEtc's Avatar
You could nail the small 2x6 pieces Ken is talking about to the joist closest to the wall. You may not have to touch the Tyvek that way. This suggestion is based on the fact I can't see what you're dealing with though.
Terry
DECKS Etc.
GardenStructure.com
DecksEtc is offline   Reply With Quote
Old 01-05-2006, 10:47 PM   #8
Well I actually have some pictures of what I am talking about. I just do not know how to insert them into the post.
Old 01-05-2006, 10:58 PM   #9
renovations
After you hit "Reply", scroll down and click on "Manage attachments", browse for the pics in your pc and attach them. They have to be small, under 100k I think, though, so you might have to mess with them before you can do that.
Old 01-06-2006, 12:21 AM   #10
alright im gonna try to attach the pic's.
These are pics of the one wall.
Old 01-06-2006, 12:23 AM   #11
these are the other wall
drywalling a ceiling-dscf0026.jpg   drywalling a ceiling-dscf0027.jpg   drywalling a ceiling-dscf0028.jpg
Old 01-06-2006, 09:16 AM   #12
Hi...I couldn't help but notice that your walls don't seem to come up flush with your cieling joists. I could be wrong, but if they are not, you're going to have a tough time scabbing a piece to tie into at the end of your drywall. When this is flush....you could simply attach some 2X6 scabs on top of your framed wall there. It will take more time to do, but it is recommended because it looks as if you have more than just 1" 1/2 space there.
fisher501 is offline   Reply With Quote
Old 01-06-2006, 04:03 PM   #13
Ya I know about the space difference. The walls were build on the floor, then lifted into space. Therefor they had to be shorter as if they were the same height they wouldn't be able to be raised into place. I built some t-shaped piece to secur the walls to the cill play so the wall is securly inplace.
The gap isn't that bad though. I think it must be the angle of the pictures. I was thinking I could screw some 2x6's into the last exposed joist, drop it on the top of the wall frameing and use some shime to make it level. Then nail my drywall to it.
Old 02-16-2006, 11:50 AM   #14
some special type of drywall clip may be your answer
I saw some special type of drywall clips selling on Ebay which for hanging ceiling drywall without enough support like your situation, may be it is your answer. or search on google for "insta-back" products.
KUIPORNG is offline   Reply With Quote
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 09:26 AM
Ceiling condensation icemand Building & Construction 1 12-15-2009 06:16 AM
ceiling fan support triplnikl Carpentry 5 03-06-2009 04:47 PM
Cathedral ceiling ventilation dpreznik Roofing/Siding 2 10-31-2006 11:18 AM
Rod Lengths for Ceiling Fans and Mini Pendants Not Sure Electrical 6 10-25-2006 12:23 AM
