Drywall Spackle-corners - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-27-2008, 09:32 PM   #1
DIY Expert in Training!
Drywall spackle-corners
First, my corners tend to be a little choppy where the ceiling and two walls meet. Any way to fix?
Second, does the walls and ceiling have to
be exactly square as a result of spackle or just smooth?
gone_fishing is offline   Reply With Quote
Old 03-27-2008, 09:55 PM   #2
Rewards Points: 150
Just smooth. Square helps fitting cabinets and such, but rarely are they found so we scribe to them.
You can go on You-Tube and watch various videos on hand or tools to do corners.
kgphoto is offline   Reply With Quote
Old 03-28-2008, 01:07 PM   #3
Rewards Points: 150
Dumb question---do you have a corner drywall trowel?? They can be tricky to run and get perfect. Tip- Dont pay as much mind to outside edge,concentrate on inner corner,then use a wide knife to wipe excess off outside edges,,,getting the corner smooth all three ways is the challenge at hand!! proper angle (and pressure)helps tons!! Try scraping off dry excess compound with a dry knife first before lightly sanding edges,,,leave the corners build up!!
justdon is offline   Reply With Quote
Old 03-30-2008, 09:06 AM   #4
I did use corner trowels. I was having trouble smoothing out the 3 way corner where the ceiling and walls meet. I used watered down mud and patience. Going to sand...hopefully for the last time...
Old 03-30-2008, 10:38 AM   #5
Done sanding...I am calling the dry wall part done. Going to prime and see if there are spots I need to touch up with spackle. Afterall, it is only a laundry room and 1/2 bath in the basement.
Old 03-30-2008, 10:17 PM   #6
I remember my first mudding attempt. It was a basement bathroom as well. I don't think I've ever cursed so much in one single day. I kept mudding and sanding, mudding and sanding, and eventually, I realized there's a technique to it... and that I was oblivious to the technique. After doing a couple of more rooms, I eventually got better, but it's always the part of the remodel I'm most apprehenisve about doing.
Good luck.
Kev
Foo by Tore is offline   Reply With Quote
Curved corners where drywall meets? SouthGAreno Remodeling 12 01-17-2013 03:10 PM
Superior Walls - Floating Corners & Drywall Woodcutter Drywall & Plaster 16 04-22-2011 12:05 PM
my corners are cracking when hanging drywall in the ceiling, why? yummy mummy Building & Construction 16 12-22-2007 12:09 PM
Corners with drywall? Ol' Luke Building & Construction 9 11-09-2006 06:17 AM
