Drywall Over Plywood - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-21-2012, 11:40 AM   #1
Drywall over plywood
Need advice:
I live in a house where my living room wall is right up against my neighbors wall (very common in Sam Francisco). I would like to make my living room wall a little more sound proof so I won't bug my neighbor and currently the wall only has plywood. I read somewhere that adding a piece of drywall over it will help. Any truth to it?
mike467 is offline   Reply With Quote
Old 04-21-2012, 12:22 PM   #2
Rewards Points: 6,652
It should be done if the wall only has plywood, especially for fire ratings. Will not stop sound, unless you use Green Glue between the sections.
Old 04-23-2012, 09:47 PM   #3
Rewards Points: 264
We used this...
http://www.nationalgypsum.com/produc...9%2000-173.pdf
on a project and it worked very well. It is basically a panel that is assembled at the factory with a layer of material similar to the Green Glue that gregzoll mentions sandwiched between 2 sheets of drywall. Finished thickness is 5/8.
7echo is offline   Reply With Quote
Old 05-29-2012, 06:09 PM   #4
Soundproofing Guy
Rewards Points: 158
Better and cheaper to use two sheets of standard 5/8" drywall and a field application of damping compound. You want all the mass you can get and pre-damped specialty drywall are lightweight.
Also drywall from Home Depot is $7 a sheet.
Ted White is offline   Reply With Quote
In wall gutter downspout causing mold on drywall. chrispy35 General DIY Discussions 12 05-06-2011 10:35 PM
Cutout in drywall around sink coutertop bananey Drywall & Plaster 4 05-04-2011 04:47 PM
Can I tile over old plywood with no gaps? JFERTICH Flooring 5 02-21-2011 02:52 PM
Attach Drywall through plywood HooKooDooKu Drywall & Plaster 2 01-20-2010 10:05 PM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 01:12 PM
