Drywall Over Open Beam Ceiling And Venting - Remodeling - DIY Chatroom Home Improvement Forum
Old 11-04-2012, 12:05 AM   #1
Rewards Points: 366
Drywall over open beam ceiling and venting
I have a home that has open beam ceilings and part of the home (living room & kitchen) had the ceiling covered by drywall by previous owner. The kitchen and living room ceiling is divided by a center beam that goes along the house as the middle of the gable roof. The living room portion seems to be vented with soffit vents on the outside wall. The kitchen expands into a room addition, and so don't see any vents on that side (addition has different roof structure, I saw no venting to the additions attic. I don't think the center beam along the gable has holes to pass ventilation between the kitchen and living room ceiling.
I don't know if the drywalled ceiling is insulated or not with any moisture barrier, w/o taking down the drywall.
I was just wondering in case ceiling wasn't insulated or vented (kitchen area), how bad could it be? If any problems, would you only notice problem when removing the drywall or doing a reroof seeing issues on top at the roofing side? Or would the problem manifest itself visibly on the drywall ceiling over time?
I live in northern California, and the drywalled ceiling is several years old, perhaps up to 10 years, but not sure.
daluu is offline   Reply With Quote
Old 11-04-2012, 12:46 AM   #2
GBrackins's Avatar
Rewards Points: 2,108
would it be possible to post a few photos?
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 11-04-2012, 01:03 AM   #3
Rewards Points: 366
Here's some photos I have on hand that I kept from home listing online when I bought the house. A bit low res but should be good enough.
original ceiling style - seen from a bedroom
https://www.dropbox.com/s/068gsm29opeigw8/6.jpg
drywalled ceiling version in kitchen
https://www.dropbox.com/s/3yy8gtesnp...139206_4_0.jpg
circular hole vents (w/ mesh netting) by front entrance, above door
https://www.dropbox.com/s/b20zwn79sf...139206_1_0.jpg
Old 11-06-2012, 09:27 PM   #4
Rewards Points: 366
here's a better pic of the open beam ceiling:
https://www.dropbox.com/s/1gl55wuq55...eamceiling.jpg
Old 11-07-2012, 01:54 AM   #5
Rewards Points: 366
Also, I think the garage is also open beam but previous own installed drywall over it to create a flat ceiling (not an angled ceiling) and I see no venting along the walls or roof of the garage. That ok or a problem? Can't confirm any issues or whether there's insulation w/o removal of drywall ceilings.
Insulating and venting a cathedral ceiling fride360 Building & Construction 7 02-23-2012 08:22 PM
cathedral ceiling soffit venting david palumbo Insulation 1 06-27-2011 08:54 PM
Venting an open cathedral ceiling spcrooks Insulation 4 06-08-2011 09:02 AM
