Drywall Or Not - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-19-2010, 12:46 AM   #1
drywall or not
my exterior wall on my 100 year old house as a whole is leaning in on the bottom, and to get my stove/oven to fit in and be up tight at the top (not 3/4" away from the wall and 3/4" father out in front of the cabinetry) i want to take out the 5/8" sheetrock from behind the stove/oven about half way or 3/4 the way up from the floor to the top of the stove so that it will seat deeper in it's place... can i use 1/4" sheetrock behind the stove/oven or is there problems because a stove puts out so much heat that the 1/4" rock won't work ? is there a heat issue here ?
homemade is offline   Reply With Quote
Old 03-19-2010, 06:20 AM   #2
If you are talking about a kitchen oven/stove, there is little heat lose from the sides or back, so there should not be a heat issue. I would tend to be more concerned about why the wall is bowed. Is there a basic support problem or is it just the years???
Old 03-19-2010, 06:25 AM   #3
kwikfishron's Avatar
Rewards Points: 596
Sure it's not your floor sagging?
kwikfishron is online now   Reply With Quote
Old 03-19-2010, 06:39 AM   #4
i think it's just years...the house has definately settled... but looks as though it's stable... i've got everything that is on that wall figured out except the stove issue and just worried about needing a certain thickness of sheetrook because there is insulation and 2x4's behind it and i don't want any possibility of a fire...
Old 03-19-2010, 06:10 PM   #5
hey homemade,
you can bubble gum it all you want back there, with any kind of drywall.
from an aesthetic standpoint it won't really be seen, even, if behind the stove,
but structurally, if you're concerned, 3/8 rock or 1/4 rock will need more support behind it (unless there is wood lathe), otherwise one little tap and it will bust. but who cares? it's behind the stove.
i wouldn't be worried about a fire.
perhaps better than drywall, though, if you are concernd about that, is to use some cement board back there.
but i would open up the wall and have a look at the sills and studs and see why it's heaving in like that, or check it out from the basement if possible.
it's possible that rather than the bottom heaving in, the top is raking OUT.
maybe it's a timber frame, and some pegs or tenons have broken, etc...
good luck
wombosi is offline   Reply With Quote
Problem Patching Large Drywall Hole FuLLTiLT Drywall & Plaster 5 11-21-2009 09:42 PM
Large drywall patches - best way to fix? Screw them to what? Scott99999 Drywall & Plaster 6 11-19-2009 04:34 PM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 01:12 PM
