Drywall Newbie - Remodeling - DIY Chatroom Home Improvement Forum
Old 06-21-2013, 11:25 AM   #1
drywall newbie
I am about to put up some paper faced metal corner bead for outside corners. Is there any reason I can't/shouldn't use construction adhesive to glue the bead to the drywall instead of using drywall mud?
n_hilo is offline   Reply With Quote
Old 06-21-2013, 01:52 PM   #2
No, the construction adhesive would be over-kill, and may even make it more difficult.
lcpms is offline   Reply With Quote
Old 06-21-2013, 02:18 PM   #3
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Not to mention if the corner gets bumped hard enough the corner bead will separate from the wall. Screw it in.
sublime2 is offline   Reply With Quote
Old 06-21-2013, 03:52 PM   #4
Rewards Points: 626
You don't screw in metal paper face beads. A metal paper face bead is set with Mud and you either use a mud hopper to put the mud on then use a Conner roller to press it on or you put the mud on the cornner and press it in and roll and use your 6 inch knife to scrape the excess mud off. In 24 hours you won't be able to kick that corner bead off.
Nailbags is offline   Reply With Quote
Is tape necessary to repair holes in drywall (in garage)? Scotch99 Drywall & Plaster 4 08-22-2011 01:08 PM
Drywall ceiling above bathtub/shower larabiec Drywall & Plaster 3 06-26-2011 01:23 PM
Newbie from Canada - Drywall Corner Bead Question Shelly A. Drywall & Plaster 4 06-11-2010 02:31 PM
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 09:30 AM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 01:12 PM
