#1 |
drywall master ran into disaster
I do drywall also painting but I have a problem im removing baseboards that were glued and nailed on whats the best way ro remove I have a flat knife and its not working well at all
#2 |
Super Moderator
You are going to lose the face of the drywall---so score the paper right at the top of the trim--then use a heavy painters tool and a hammer---and peel off the junk trim--and the top layer of the drywall--
New members: Adding your location to your profile helps in many ways.--M-- |
#3 |
do not worry jennifer i am here even using run on sentences lol and mike has the same solution as i do and have done. do not worry about your grammer just come back if you have another question or have an answer for another post
be careful my advice only comes from general knowledge i know about the 4 rules it takes to plumb and they are 1 poop needs to flow down hill. 2 hot on left cold on right 3 i get a pay check on Mondays 4 do not chew finger nails at or after work. |
| The Following User Says Thank You to jaydevries For This Useful Post: | creeper (07-18-2012) |
| Display Modes | |
| Reno Disaster.. DRywall fix up.. | ABElectrician | Drywall & Plaster | 11 | 06-26-2011 11:08 PM |
| Drywall ceiling above bathtub/shower | larabiec | Drywall & Plaster | 3 | 06-26-2011 02:23 PM |
| In wall gutter downspout causing mold on drywall. | chrispy35 | General Discussion | 12 | 05-06-2011 11:35 PM |
| Cutout in drywall around sink coutertop | bananey | Drywall & Plaster | 4 | 05-04-2011 05:47 PM |
