Drywall Estimate - ATLANTA - Remodeling - DIY Chatroom Home Improvement Forum
Old 05-26-2005, 09:34 PM   #1
Hello - I am currently finishing my basement and have decided to contract out the drywall hanging and finishing. I live in Atlanta and a 4x8 1/2 piece of rock is around $7.30. I am trying to determine a good estimate for hanging and finishing. I have heard anywhere from $20 on the low side to $30/sheet (supplying the material, hanging and finishing) My project is around 110 4x8 sheets. (about 1000sf iplus ceilings)
Thanks is advance.
John
eddle6389 is offline   Reply With Quote
Old 06-04-2005, 09:17 AM   #2
Merryman Drywall
Judging your location and what you pay for an 8 footer I would think even 30 would be on the low side.
Sheetrock26 is offline   Reply With Quote
Old 05-31-2011, 10:10 PM   #3
I usually charge about $35 per sheet for basic hanging and finishing. Properly mudding, taping, and sanding drywall is the key to a nice paint job. I may be able to do a little better the $7.30 per sheet. Let me know if I can help you.
jjackson is offline   Reply With Quote
Old 06-03-2011, 03:10 AM   #4
wow at 30 per sheet by 110 sheets that comes up on the cheap side definitely, different area though.
chrisBC is offline   Reply With Quote
Old 02-01-2012, 11:15 AM   #5
Always get three estimates from Atlanta drywall contractors
If you're looking for an estimate, I'd suggest contacting several and ask if they give free estimates. When working with contractors, it's recommended to always get at least three estimates before hiring one to do the job. If you're on a tight budget, let your contractor know that upfront. If he isn't willing to work with you to find products that fit your needs, keep looking until you find one who will.
Last edited by Gary in WA; 02-01-2012 at 10:04 PM. Reason: Ad link removed per forum rules.
alkatie is offline   Reply With Quote
Old 02-01-2012, 12:38 PM   #6
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,074
Look at the date. I'm guessing this guy already has this done.
The Following User Says Thank You to Blondesense For This Useful Post:
Willie T (02-01-2012)
Old 02-01-2012, 01:10 PM   #7
Old School
Willie T's Avatar
And this little fact was caught by a blonde, guys. Our gals on DIY are sharper than most guys!
Willie T
The Following 2 Users Say Thank You to Willie T For This Useful Post:
mae-ling (02-01-2012), oh'mike (02-01-2012)
Old 02-01-2012, 10:07 PM   #8
Registered User
Rewards Points: 4,924
Good catch! You can also just hit the red "exclamation point" and a Mod. can help remove the ad.
Thanks, Gary
Gary in WA is online now   Reply With Quote
General easy drywall question bigboyjoel Building & Construction 3 05-27-2007 09:52 AM
Celing Drywall and Hurricane Clips Ricky D Building & Construction 2 04-09-2007 06:59 PM
Drywall thickness on ceiling question. Doug Crf Building & Construction 3 08-28-2006 06:47 AM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 08:11 AM
