Drywall On Concrete Block? - Remodeling - DIY Chatroom Home Improvement Forum
Old 05-31-2012, 08:14 AM   #1
Drywall on concrete block?
I am soon buying a house and have plans to finish the basement (bi-level.) It already has drywall on walls, but one wall, where the coal stove is, has a ledge with concrete block exposed (starts from floor and goes about 3 feet up wall, drywall above that.) I was hoping rather then frame over the block I could just glue on drywall. Would this be ok?
TSGR is offline   Reply With Quote
Old 05-31-2012, 08:27 AM   #2
Trucon01's Avatar
Rewards Points: 510
NOOOOOO. Never have drywall on concrete use small firring strips and then drywall at the least.
Basement Demo started Jan 2012: View my basement progression!!!
Bathroom demo started Feb 2013: View my bathroom progression!!!
Trucon01 is offline   Reply With Quote
Old 05-31-2012, 09:00 AM   #3
Gotcha thanks
Old 05-31-2012, 03:37 PM   #4
DIY staff
Rewards Points: 7,174
I've done it a few times---never had an issue---large globs of PL Premium and a few short concrete nails into the mortar lines to hold the sheet in place until the glue set up---
Old 05-31-2012, 05:47 PM   #5
if it's not a foundation wall (the way you describe it, it doesn't sound like it is), then it should be fine with glue and tacks like described above.
not sure i'd want to put it on a foundation wall though.
sevenlol is offline   Reply With Quote
Old 05-31-2012, 05:49 PM   #6
Rewards Points: 512
i've glued it on with drywall compound. get a 4-6" knife and slap it on the back. i put a mud pie about every 2' stick it on the wall and work in it a bit. hammer some 3/4" into it just to hold it in place till the mud dries.
princelake is offline   Reply With Quote
Old 05-31-2012, 08:11 PM   #7
Trucon01's Avatar
Rewards Points: 510
Can you do it yes, is it recommended, no
Also, is your foundation wall plumb?
The Following User Says Thank You to Trucon01 For This Useful Post:
oh'mike (06-01-2012)
Old 06-01-2012, 09:23 AM   #8
Not sure if it's plumb, I don't actually own the house yet..
For those saying no, why? Moisture?
Old 06-02-2012, 06:38 AM   #9
DIY staff
Outside walls sweat---without an air space or insulation the drywall will become damp and eventually grow mold---so reserve this method for interior walls only---
Concrete block grouting - what product and how much howzitmybro Concrete, Stone & Masonry 7 05-10-2012 03:35 PM
concrete block house shower medalta Building & Construction 3 11-02-2011 05:16 AM
Prep Concrete Block Wall for Natural Stone Veneer SCPete Building & Construction 2 03-06-2011 11:19 AM
New window in concrete block wall swill777 Building & Construction 3 08-02-2010 01:28 PM
window return in concrete block house bmancanfly Building & Construction 2 05-18-2009 07:32 AM
