Drywall Around A Fireplace - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-12-2011, 01:31 PM   #1
drywall around a fireplace
My husband and I are gutting our old plaster walls so we can update the wiring and insulate. We will replace the walls with drywall. We have non working fireplaces with beautiful mantels in each room and I really don't want to remove the mantels. Can we remove the plaster walls around the chimney and replace with drywall without removing the plaster or mantels from the fireplace?
jenpeitz is offline   Reply With Quote
Old 01-12-2011, 02:12 PM   #2
Experienced
Jackofall1's Avatar
Post some pictures, this would help us alot in helping you.
Old 01-12-2011, 02:41 PM   #3
Rewards Points: 5,336
It depends on the shape of the mantel. I'd be hard pressed to do it with mine.
Better you leave the plaster around the mantle alone and butt the new sheetrock to it. The framing around the fireplace shouls extend out far enough so you could tape a compound as well as have a nailing surface.
Ron
Old 01-13-2011, 04:10 PM   #4
It would be a pain but you could use a utility knife and cut the plaster out where the plaster and mantle meet...then when installing the new drywall just butt it up against the plaster on the backside of the mantle, making a flush seam
JohnDeereGreen is offline   Reply With Quote
Drywall over a brick fireplace?? Mom2JoMoLa Remodeling 0 06-13-2010 10:21 AM
Hanging drywall around stone fireplace. kossuth Drywall & Plaster 1 06-04-2010 08:24 PM
Removed tile around fireplace, drywall underneath?! Fropitar Building & Construction 37 06-02-2010 09:11 PM
Added new Fireplace Surround need drywall tips rocketdoctor Drywall & Plaster 2 12-06-2009 07:14 AM
Drywall around a fireplace Gig Drywall & Plaster 1 04-16-2009 02:33 PM
